Re: If 1 carb is good , 2 must be better [Re: tex013] #1226184
05/04/12 02:17 PM
05/04/12 02:17 PM
Is it fat at idle or part throttle? If so that will hurt the 60 ft. times and the rest of the run, which size needles and seats are in the carbs? Which size squirters? To big of squirter shots woll slow it down also on the 60 ft. Put the biggest ones(needles and seats) you can in them and the smallest sqirters that don't stumble
Re: If 1 carb is good , 2 must be better [Re: sixpackgut] #1226185
05/04/12 03:43 PM
05/04/12 03:43 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
interested to know how even your plugs look on each cylinder. surging is a lean condition. what size engine is this setup on?
Dan at Performance only made me a couple lids that match the barrel sizes of the 650 avs carbs. I use the chokes on the carbs and the car runs every bit as good as my daily driver now. its really amazing. the only thing I did to the carbs was change the pumps in the carbs. I dont have any dyno or track info though to compare it to my six pack setup I had on it.
Is it possible to get the plenum too big? If so, how do you know what is too big of an area or too small?
Re: If 1 carb is good , 2 must be better [Re: Dodgeguy101] #1226186
05/04/12 04:22 PM
05/04/12 04:22 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have done a bunch of research on this very subject. i was worried about mine but from what i have read, an engine would want a plenum the same CI or larger as the engine. Some prefer up to 150%. my plenum on the sheetmetal ram i posted comes in at around 410 CI compared to my 493 engine. the plenum on my weiand tunnel ram i was useing is much smaller
look at the plenum size of the Indy bathtube intake and it seems to work very well except for the fact that it has alot of places for fuel to puddle
Re: If 1 carb is good , 2 must be better [Re: sixpackgut] #1226187
05/05/12 07:59 AM
05/05/12 07:59 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks for the ideas.
went out again car ran the same but the driver - damn nut behind the wheel.anyway good to watch some doorslammers,prostock,alky and nitro cars.even had a chat with Cory Mac who is over here to race this weekend
after a lot of thought and talking to others i guess i have a game plan of sorts.
i have a Prostreet meeting in 2 weeks so will swap back to the single carb,picks back up et and some mph.
it may simply be the modman plenum may simply be too large for my ci and rpm range.i have a 440+0.055 ,leave off the footbrake at 2500-2700, shift at 6000,trap 635-6450.this could lead to a poor signal hence having to jet up a lot and leading to a lazy launch.with the manifold off i can set up a cross shaped insert to not only reduce volume but also maybe help direct and speed up the airflow. a mate of mine who races a stroked 409(476ci) chev W motor said Lamar Waldren does a similar intake for these motors and some guys using stock ci or lower RPM motors were finding they needed inserts to get the best results.i may also try something in my M1.
so i can see improvements to come .
BUT it may be this manifold may suit a stroker motor more readily,particularly in a six pack setup.
as to bigger cfm carbs i would think there would be an even more reduced signal,though with an improved signal they might work.
i know on my motor when i tried a ultrahp 950 about a year ago the car lost 3/10 and nearly 3 mph over my BG825.and a hp1000 based carb goes a little better et and mph.
as the saying goes - "your experiance may vary"
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: If 1 carb is good , 2 must be better [Re: tex013] #1226188
05/05/12 08:33 AM
05/05/12 08:33 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
have you tried to advance the cam to help with the lower RPM?
Re: If 1 carb is good , 2 must be better [Re: Clanton] #1226189
05/05/12 09:57 AM
05/05/12 09:57 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i dont think the plenum volume is the problem, I think the short runners are
Re: If 1 carb is good , 2 must be better [Re: sixpackgut] #1226190
05/05/12 11:31 AM
05/05/12 11:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What cam are you running? It might want a higher 1-2, 2-3 shift. I also found out last time at the track my car 60 foots better when I go from 1500ish and stand on it then when I pull the rpms up against the convert (26-2800ish) I'm running a Turbo Action 3800. As mentioned take a box of rods with you next time and try a few things. I'd bet you a 6-pack that a pair of holley 650DP's would do wonders. Good luck.
Re: If 1 carb is good , 2 must be better [Re: sixpackgut] #1226191
05/05/12 11:00 PM
05/05/12 11:00 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
sixpack,
that is also consideration of building an insert to help direct air into the runners.almost like extending them.
MrYuck,
i also think holley type carbs would be better but won't fit this top.Maybe a type like shown by A57RT in the small block manifold thread would
As to tuning at the track i did try a couple of rod and spring changes.Best 60' was with the most fuel and silver spring.But with the silver spring there was some surge,rich,at light idle.Yellow springs are fine.I did find without the silver spring on the dyno and road,but not strip,there was a heasitation as you hit the throttle to the floor from cruise.so it does look like a signal issue leading to fuel issues
oh well 1 step forward - 2 steps backward.
all in the pursuit of speed
Tex
New best MPH 130.32
Re: If 1 carb is good , 2 must be better [Re: tex013] #1226192
05/05/12 11:53 PM
05/05/12 11:53 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Tex, on my 650 avs carbs i took out the stock pump and put in the one that comes in the 800 carbs. I also drilled my squirters out from .031 to .037
stock on left. you can see the differnce
Re: If 1 carb is good , 2 must be better [Re: sixpackgut] #1226193
05/06/12 06:48 PM
05/06/12 06:48 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Sixpack thanks for the pic
took the manifold off yesterday arvo and will play around with insert style over the next week or two.Will also talk to Ben at Promax .
I do see a better result as looking at mph i am not far off the power now
i am stuffed why the pics are so low resolution,will try again
Tex
New best MPH 130.32
Re: If 1 carb is good , 2 must be better [Re: tex013] #1226194
05/07/12 07:58 AM
05/07/12 07:58 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Look at the picture I posted earlier. Notice the carb spacers. Those are 1" 4-bore. They really make a difference. BUT, the stock hood difinetly will not fit with them.
Re: If 1 carb is good , 2 must be better [Re: Cudajon] #1226195
05/07/12 08:24 AM
05/07/12 08:24 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
I would really consider trying a spacer, if it picks up try another, as I did mention in my post on the small block, the BB mod mans we tried with dual 4s just as my sp was very blah and not very responsive and didnt even seem to want to transition to wot well.
As for a few mods in the plenum, a very good Idea the closer 4 ports do try to rob all it can which leave the outter 4 lacking.
I didnt go as extreme as I would if it were a single 4 and would do a dual 4 even different.
Re: If 1 carb is good , 2 must be better [Re: Cudajon] #1226196
05/07/12 07:00 PM
05/07/12 07:00 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Cudadon,
i don't have too much of an issue with clearance as i have a six pack scoop/hood,i can prob go 2" spacer no worries and still run a 3" filter
A57RT,
i will try spacers,but want to get a insert done as well.easier to make up off car.plus like i said have a meeting on the 19th
Tex
New best MPH 130.32
Re: If 1 carb is good , 2 must be better [Re: tex013] #1226197
05/14/12 09:20 PM
05/14/12 09:20 PM
Beyond the sun
Bakerlite Offline
Bakerlite  Offline
Beyond the sun
Tex, It's about time I gave you something to think about.
You've been swapping cams, carbs, manifolds, jetting etc to no avail.
You've got a massive fuel system so , delivery, jetting etc is not going to be the problem.
The cam swap was a bit of a stab in the dark because when you put that cam in the other motor it had way too may variables being changed at the same time as well as having different cubes and heads. Although you did see a power increase in that engine,there was no way to say for sure how much extra power was being delivered by just the cam.
Infact your own engine may have not realized the full potential of that cam or the new one you have put in because of one factor.
Your cylinder heads.
You and I have talked about this before.
I'd say they are the choke point of your engine.
Although they are ported, they were done by a guy without the aid of a flow bench and who knows what quantifiable experience he has, as head porter. This could mean your heads flow better, the same, or worse than straight out of the box. You have no data to go by on this subject.
You have always had the attitude that your "RV" cam was what was determining the performance of your engine, when infact it was most likely the biggest cam that your combination would accept.
I think it's time for you to seriously take a look at these heads because your spending $$ hand over fist and going in circles.
