2003 Dodge Neon battery drain #1225695
05/01/12 10:16 PM
05/01/12 10:16 PM
Georgetown, TX
sc4579 Offline OP
sc4579  Offline OP
Georgetown, TX
My wife's 2003 Neon just started having a drain on the battery. Using a VOM if checked current draw and found .500ma draw. I pulled fuses until I found the radio/Int light fuse caused it to drop. The dome light is not staying on and there is no glove box light. What else could it be?
I do not have a wiring diagram to trace the wiring.
Any help is appreciated.
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: 2003 Dodge Neon battery drain [Re: sc4579] #1225696
05/02/12 12:01 AM
05/02/12 12:01 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
trunk light? and i have seen radios that cause a draw like that. Easy way is to unplugged the radio to see
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 2003 Dodge Neon battery drain [Re: sreinheimer] #1225697
05/02/12 08:28 AM
05/02/12 08:28 AM
Ohio
john55 Offline
john55  Offline
Ohio
had one a few years ago, open the trunk and unplug it
The Plymouth Win You Over Beat Goes On
