Mopar "420" Iintake 4500 top for 440 CI SB #1225618
05/01/12 08:29 PM
05/01/12 08:29 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Just got this done last night now it has long trip to Australia.
Cross section starts at about 4.5SQ"(ave) and is 2.95SQ" at the flange should make real nice power 4000rpm to 7500~7800rpm.
This will be matched up with set of my CNC W9s on a street/strip car. It should be a fun ride.
Brett Miller
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: W5DART66] #1225619
05/01/12 08:30 PM
05/01/12 08:30 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
#2
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: W5DART66] #1225620
05/01/12 08:31 PM
05/01/12 08:31 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
#4
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: W5DART66] #1225621
05/01/12 08:32 PM
05/01/12 08:32 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
#5
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: W5DART66] #1225622
05/01/12 09:06 PM
05/01/12 09:06 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
I wish you had a program for that. Sure looks nice.We come up with a new water manfold to use on the new W-8.Would like to make some if others are interested.
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: W5DART66] #1225623
05/01/12 09:18 PM
05/01/12 09:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good Brett.. I just milled mine straight across
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: MR_P_BODY] #1225624
05/01/12 11:36 PM
05/01/12 11:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Why would you make it a cloverleaf? You think it makes more power this way? Looks good though, monster ports!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: 1967dartgt] #1225625
05/01/12 11:52 PM
05/01/12 11:52 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I have done it both ways I don't think it has much affect on power but I have not done back to back test to prove that.
This is for lower RPM street strip car so may help at lower RPM.
Re: Mopar "420" Iintake 4500 top for 440 CI SB [Re: W5DART66] #1225626
05/02/12 02:48 PM
05/02/12 02:48 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I was going to say the same thing about the cloverleaf..but in lower rpm it might help..You ought to take alook at one with all the mods for max effort N/A..I would post mine but I would probably get death threats From Uratchko,BES and Tim Davis
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
