Re: rearend lube
[Re: 3wracing]
#1225063
04/30/12 11:26 PM
04/30/12 11:26 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Any good brand of GL4, 75-90 WT, 85-140 WT will work and a good bottle posi additive
Re: rearend lube
[Re: ahy]
#1225065
05/01/12 12:20 AM
05/01/12 12:20 AM
Posts: 1,487 STL
cdstl
STL
Where do you find the Sure grip additive?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: rearend lube
[Re: JohnRR]
#1225067
05/01/12 12:30 AM
05/01/12 12:30 AM
moparpollack
Lil Herman
Lil Herman
85086
auto parts store right next to the gear lube usually.
Or at the stealership!
Re: rearend lube
[Re: 3wracing]
#1225068
05/01/12 12:34 AM
05/01/12 12:34 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
what is the best gear lube for a 741 -742 suregrip
If it has a clutch type SG unit, use the real strong smelling green additive. You can find it at your local Ford dealer. No one else sells it to my knowledge. It is THE recommended fluid for these units. Some of the other brands will cause the unit to chatter. Disregard the gear lube that "needs no additives". You will surely get a chatter if you use those.
You have been warned though. DO NOT let any of that stuff touch your hands, your clothes or anything else that you dont want to destroy forever. You will never get the smell off. Your wife or girlfriend will probably kick you out of the bedroom for at least a month.
MB
Re: rearend lube
[Re: ahy]
#1225069
05/01/12 02:51 AM
05/01/12 02:51 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I get the the 90wt with the additive in it.
I am truckless..
