tubular k member #1225022
04/30/12 10:09 PM
04/30/12 10:09 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
who makes the best tubular k member kit for ebody cars?
I have found 3 kits
magnumforce ,qa1 or anthony jones
are there any other kits out there?
Re: tubular k member [Re: BUBBAZ572] #1225023
05/01/12 02:27 AM
05/01/12 02:27 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
RMS...
Re: tubular k member [Re: Jim_Lusk] #1225024
05/01/12 02:36 AM
05/01/12 02:36 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
RMS...
RMS is tubular?
Tony
70 AARCuda Vitamin C
Re: tubular k member [Re: 70AARcuda] #1225025
05/01/12 03:56 AM
05/01/12 03:56 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
RMS...
RMS is tubular?
Well, not quite tubular, but aftermarket coil-over. Personally, I'd never buy any of 'em, but RMS has the best reputation out there.
Re: tubular k member [Re: 70AARcuda] #1225026
05/01/12 12:08 PM
05/01/12 12:08 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
RMS...
RMS is tubular?
Yes, square tube.
There are also Control Freaks, which is a round tube copy of the RMS, and the XV Level 2 stuff.
To the OP, what requriements define "best" for your application? Obviously each manufacturer thinks their solution is best or they wouldn't offer it. Do you need lighter weight, durability, ease of spring swaps, use of stock components, geometry improvements, or what???
Re: tubular k member [Re: TC@HP2] #1225027
05/01/12 12:12 PM
05/01/12 12:12 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Ive been banging the RMS system hard for 4 years now in alot of different setting and do a simple inspection and bolt check when I change front springs and its been flawless.
Its a part thats simple to install/setup maintain and with reg inspection out of simple common sense, you never have to worry about it.
Re: tubular k member [Re: quick77rt ] #1225028
05/01/12 02:14 PM
05/01/12 02:14 PM
NY usa
540challenger Offline
NY usa
Another vote for the RMS. I have installed 3 units into customers and mine own car. Only had the front end in since sept. 2011 but i racked up 3500 miles with no problems. Also it makes it a dream to work on the engine
Re: tubular k member [Re: 540challenger] #1225029
05/01/12 06:07 PM
05/01/12 06:07 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I've never seen a bad thread about RMS K kit on Moparts. I have seen another brand K kit at the track, the car couldn't back up more than 10 feet. I don't get hung up about RMS not being all round tube, it looks strong enough for the street. Most important reason I bought RMS, I didn't want to gamble $3600 on a K member kit that didn't fit or drive correctly.
Re: tubular k member [Re: B5 Bee] #1225030
05/01/12 06:50 PM
05/01/12 06:50 PM
Andrewh Offline
Andrewh  Offline
saw this on some tv show.
looked interesting as an alternative.
http://www.schwartzperformance.com/index...de=cat/cat5.htm
Re: tubular k member [Re: BUBBAZ572] #1225031
05/01/12 06:50 PM
05/01/12 06:50 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I love the RMS system, front and rear, but I can't tell you if there is a better one because I installed two, both RMS, and that's the only one I tried. I will tell you that it's going opn three years and a few thousand and no probs.
Re: tubular k member [Re: BUBBAZ572] #1225032
05/01/12 06:57 PM
05/01/12 06:57 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
If the QA1 piece for the mopar is on par with the mustang ones, I'll have one.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: tubular k member [Re: AlexP] #1225033
05/01/12 07:41 PM
05/01/12 07:41 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
RMS
Re: tubular k member [Re: johnscudashop] #1225034
05/01/12 08:11 PM
05/01/12 08:11 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Is it a race car or street car?
Drag car you also have Bob's Pro Fab who makes a great setup.
Street car RMS all the way.
I can tell you from personal experience to stay far, far away from an Anthony Jones Mopar kit.
