car in question is a 69 Coronet R/T w/ AC....
does the engine ground attach in the conventional spot [just to the right of the ballast resistor hole (looking from front of engine bay)on the firewall] or does it go with the AC blower motor ground under a single bolt just to the top right of the AC motor?
reason I ask is:
1) the repro ground strap does not reach all the way up to the near ballast location, but this ground strap was specific to AC cars
2) when I disassembled the car the 2 grounds were under one bolt near the AC motor
So I think for AC cars it goes in the lower firewall position, but wanted to check.
TIA
