727no low gear mystery? #1224658
04/30/12 02:21 AM
04/30/12 02:21 AM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
I have a brand new 727 TCI streetfighter trans put it in three days ago and have been babying it. The kickdown was set corectly that i was sure of. Now it wont kickdown. It will shift down from D to 2nd but not 2nd to first. It wont start out in first either. The only way to get it into first gear is put the car in park then quickly shift to first. Think this is a governor prob?
Re: 727no low gear mystery? [Re: 1976Fury] #1224659
04/30/12 10:23 AM
04/30/12 10:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So you have no first gear if you manually shift to low ?
Re: 727no low gear mystery? [Re: JohnRR] #1224660
04/30/12 10:33 AM
04/30/12 10:33 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
i was told once that was the symptom to a bad sprag--also when the sprag goes out it damages the case---bob
Re: 727no low gear mystery? [Re: 1976Fury] #1224661
04/30/12 06:52 PM
04/30/12 06:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Manual low doesn't use the low roller clutch "sprague". If it backs up and goes forward in 2nd and 3rd all your clutches and bands are functioning. I would think it's a valve body issue.
Doug
Re: 727no low gear mystery? [Re: 1976Fury] #1224662
04/30/12 09:57 PM
04/30/12 09:57 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Seeing that this is my only form of transportation these days i drove it this morning and it magically fixed itself. It still makes me wonder what it was that caused the issue
Re: 727no low gear mystery? [Re: 1976Fury] #1224663
05/02/12 02:45 PM
05/02/12 02:45 PM
dogdays Offline
dogdays  Offline
The word is sprag. It should really be called an overrunning clutch.
It's not a brand name of capacitor, which is what Sprague is.
R.
PS: Every single "magically fixed itself" problem that I have ever had has come back and bitten me, hard.
Re: 727no low gear mystery? [Re: 1976Fury] #1224664
05/02/12 03:33 PM
05/02/12 03:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Shift linkage ajustments will act like that, especailly aftermarket floor shifters
Re: 727no low gear mystery? [Re: Cab_Burge] #1224665
05/02/12 06:18 PM
05/02/12 06:18 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
its the stock linkage so???? but yes im hoppin this thing dont come back to bite me in the butt
Re: 727no low gear mystery? [Re: 1976Fury] #1224666
05/02/12 06:29 PM
05/02/12 06:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if the sprag let go it won't bite up that high if the front drum come thru the floor .
slowly accelerat up to about 15miles an hour , shifter in drive, then let off the gas , does the car slow down or appear to freewheel ?
