Re: Timing wonky on 340
[Re: Dodgem]
#1224506
04/29/12 10:38 PM
04/29/12 10:38 PM
Posts: 885 alberta
Publicbottle
alberta
No dial back light...just a standard one. I cant see any indications at all when on the #1 wire. ![](/ubbthreads/images/graemlins/shruggy.gif) Ya my timing cover has the indications on the drivers side.... i tried to retard the timing by moving the distributor and the car nearly died as it approached 25-30 ish......Im aiming for approx 8 degrees correct?
[Re: Publicbottle]
#1224507
04/29/12 10:51 PM
04/29/12 10:51 PM
RapidRobert
I'd put the timing marks on 10BTDC #1 compression and the magnet dead even with the tooth and #1 plug wire over the rotor.
[Re: RobX4406]
#1224509
04/30/12 12:25 AM
04/30/12 12:25 AM
Posts: 885 alberta
Publicbottle
alberta
what distributor and box if you have one?
MP dist and MSD box perhaps? Check to see if the wires are criss crossed coming out of the distributor. May need to reverse them, seen some wacky things in the past with that set up.
As mentioned, bring it to TDC #1 firing and start over Lining everything up, rotor with #1 wire cap tower.
Hey, I have the MP Elect ignition kit.....which included the orange ECU, volt regulator and distributor. Thanks for the suggetions...ive heard of issues with these new parts...will check it out and report back!
[Re: Publicbottle]
#1224511
04/30/12 06:16 PM
04/30/12 06:16 PM
Posts: 885 alberta
Publicbottle
alberta
Update! Ok, i just re-looked over my setup. plug wires were ok, i set my balancer to 10BTDC and took off the dist cap and lined up the reluctor to the magnet and ensured the rotor was at the #1wire. fired her up and there it was! with the timing light i saw the mark at approx 10BTDC at idle. when I advance the throttle to around 3000rpm the timing mark dissapears under the water pump pulley. Which leads to my next question....how do you set advanced timing in this case? Thanks for everyones help so far ![](/ubbthreads/images/graemlins/thumbs.gif)
