Electrical Question #1223709
04/28/12 07:33 PM
04/28/12 07:33 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
2 years ago my son bought a 68 coronet with out engine and trans. After body work/painting it and putting everything back together we have a electrical problem. The only things that work are the brake lights and dome light. No dash lights or head lights.New battery and both cables.What to look for .
Re: Electrical Question [Re: 493RT] #1223710
04/28/12 08:09 PM
04/28/12 08:09 PM
you could see if the dimmer switch has fire then either go downstream from there to the headlights or backtrack up to the headlight switch. www.mymopar.com has wiring diagrams/colors
Re: Electrical Question [Re: RapidRobert] #1223711
04/29/12 12:55 PM
04/29/12 12:55 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
brake/dome share same fuse. off battery circuit
lights are off the battery circuit too- no fuse- but all light power is thru the headlight switch- check to see if there is power there- look for burnt melted connector.
if no other power to ing. switch- check wires to it for same burnt.melted problems
Re: Electrical Question [Re: 493RT] #1223712
04/29/12 12:57 PM
04/29/12 12:57 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Have you checked for a good ground?
I have mechanical Aptitude.
I can screw up anything.
Re: Electrical Question [Re: 71_deputy] #1223713
04/29/12 03:36 PM
04/29/12 03:36 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Thanks guys.... After talking to him , he remembered that he unplugged the wire harness to the 2 switches on the dash.
Everything lights up now..
Re: Electrical Question [Re: 493RT] #1223714
04/29/12 04:14 PM
04/29/12 04:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
now that's an easy fix, huh?
Re: Electrical Question [Re: bboogieart] #1223715
04/29/12 04:15 PM
04/29/12 04:15 PM
yeah that was too easy
