tighter valve lash with roller rockers ? #1223609
04/28/12 04:36 PM
04/28/12 04:36 PM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
I would like to know if it is better to run a tighter valve lash than the cam card recomendation when using roller rockers.
I have a 440 with a comp cams solid lifter setup .502 lift. The cam card says .016 intake and .018 exaust. I am using Harland Sharp rockers. Would it be better for the roller bearings in the rockers if I ran less lash gap? maybe .012 lash?
Re: tighter valve lash with roller rockers ? [Re: allmopar] #1223610
04/28/12 07:50 PM
04/28/12 07:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the type of rocker doesn't dictate lash settings. the rocker ratio will affect minimum settings. i wouldn't do .012. thats about .008 at the lobe with a true 1.5 rocker and those harland sharps will probably measure a true 1.6. i use .010 clearance at the lobe as the minimum hot setting. so, multiply .010 by the true rocker ratio and use that as the minimum.
Re: tighter valve lash with roller rockers ? [Re: allmopar] #1223611
04/28/12 11:55 PM
04/28/12 11:55 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What is the reasoning behind this? The higher ratio accuracy of a roller vs. stamped?
