temp senders question #122346
09/17/08 09:09 PM
09/17/08 09:09 PM
S/NH
hemijimbo Offline OP
S/NH
my temp gauge was acting a bit erratic, so I purchased a new sender, upon install it was reading way higher then what was possible for the time the engine had run,high In the hot zone,in less then 1 minute, are there more then one type of sensor??, 69 rr, thanks
Re: temp senders question [Re: hemijimbo] #122347
09/17/08 09:13 PM
09/17/08 09:13 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
They read on resistance, it's quite possible your sender is faulty. I'd try another one.
Re: temp senders question [Re: Dart 340] #122348
09/18/08 01:17 PM
09/18/08 01:17 PM
Arkansas
GregGarner Offline
GregGarner  Offline
Arkansas
Temp sender should read 80 ohms (or higher) when cold, and it would read 10 Ohms when it was fully hot, to make the gauge read the highest mark. If you disconnect the wire from the sender then you can measure the resistance of the sender to ground.
GregGarner
www.rt-eng.com
Home of the mopar solid state limiter adn tach repair kit
