Re: Final Showdown: traction bars - YES or NO? [Re: Mr.Yuck] #1223303
05/01/12 11:50 AM
05/01/12 11:50 AM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
traction bars should be pushed forward up under the leaf spring mount, not under the spring itself.
The operative and key word here is SHOULD. Since most slapper bars are sold for GM F bodies, they tend to be sold in lengths that bolt directly on to these cars. Sticking them under a mopar means they end up in some position other than the optimal. Now, I don't doubt that back in teh day some manufacturer somewhere had taken the time to measure and layout a set up that would work properly with differing mopar applications, but my bet is that most have not and do not take that into consideration and most of these are sold as a universal application.
Re: Final Showdown: traction bars - YES or NO? [Re: TC@HP2] #1223304
05/01/12 11:55 AM
05/01/12 11:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You can get direct fit units...they are 3-4x the cost of the uni's.
Re: Final Showdown: traction bars - YES or NO? [Re: Mr.Yuck] #1223305
05/01/12 12:57 PM
05/01/12 12:57 PM
Pikes Peak Country
Pikes Peak Country
That doesn't surprise me.
So I guess the question for the OP is are you willing to pony up the $$ for the correct style slappers or are you looking to make your $20 swap meet scored units fit?
Another reason to not like slappers, their low hanging position makes them susceptible to speed bump damage. Hit one of these at speed, and you could really mess up some stuff under your car.
Personally, I'd try adding clamps to my front segment before going to a set of slappers. I'd even try adding more leafs or half leafs before going slappers.
Re: Final Showdown: traction bars - YES or NO? [Re: TC@HP2] #1223306
05/02/12 02:54 AM
05/02/12 02:54 AM
delivering your oil
nutso suave Offline OP
delivering your oil
i was thinking of adding some period correct ansen ground grabbers.
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223307
05/03/12 11:10 AM
05/03/12 11:10 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
I put a set of caltracs on my 72 cuda yesterday. Don't know if they help anything but they sure look tough. Pinion snubber was beating a hole in my floor pan and that's the real reason i put them on. Biggest problem was pushing out the old bushing.
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223308
05/03/12 11:23 AM
05/03/12 11:23 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Care must be taken when selecting traction bars. Make sure they don't contact the ground when a rear tire goes flat. Bad things WILL happen. DAMHIK.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Final Showdown: traction bars - YES or NO? [Re: DARTH V8Я] #1223309
05/03/12 12:17 PM
05/03/12 12:17 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I would never use traction bars because a: they look stupid and b: they look way too GM to me (sorta like cowl hoods! )
In any case, I think an adjustable snubber or proper spring setup does the trick just fine. I've owned dozens of GM cars and the main reason for the traction bars were the very weak stock springs compared to a Mopar HD setup.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223310
05/03/12 12:22 PM
05/03/12 12:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i am going to reinstall my cheap lkwd bars at some point and with the u bolts it can be moved to hit the spring eye and is not locked on to the axle pad.give it a shot if you have the $$ but most of all do what you want. do you have any video of the car launching?
Re: Final Showdown: traction bars - YES or NO? [Re: Clanton] #1223311
05/03/12 12:39 PM
05/03/12 12:39 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would not use traction bars on a Mopar. I dont use anything other then SS springs that are clamped in the front. Not the greatest 60 but it has pulled a 1.50 on old slicks. Ron
Re: Final Showdown: traction bars - YES or NO? [Re: Dean_Kuzluzski] #1223312
05/03/12 01:19 PM
05/03/12 01:19 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
but since then several drag racers have told me that traction bars work better than adjustable pinion snubbers.
CalTrac's obviously work and they are slapper bars that were refined to a fully functioning level. The "poor man's 4-Link" as one could say. They basically reapply the wind-up forces into a downward motion for the axle.
And one of the reasons the old Direct Connection manuals pumped up the P-snubber and rejected the slapper bars was to sell their own product.
the mopar spring design with the assymetrical leafs (short front segment, long rear segment) are basically a leaf spring trying to be a ladder bar. in theory, the front segment is essentially rigid (especially if the leaves are clamped), and all of the flex is in the rear segment.
a cal-trac is a better version of the same thing. it replaces the spring pack usually with a single spring, where the front segment isn't as stiff as the stock one), and uses the bars as the link to locate the axle relative to the body.
traction bars/slapper bars are used to control axle wind-up in symmetrical/long front segment springs. they typically aren't clamped to the front of the spring, but are designed to make contact with spring wind up (hence "slapper bars". being clamped to the springs, cal-tracks are a totally different animal, they basically turn a mopar leaf spring setup into a quasi leaf sprung ladder bar setup. a true leaf sprung ladder bar setup would have the ladder bar pivoting on the body, and shackles front AND rear on the leaf spring.
my boss actually designed and built a leaf sprung 4 link setup for his trail wrangler.
2017 Grand Cherokee Overland
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223313
05/04/12 03:27 PM
05/04/12 03:27 PM
organ
maximum entropy Offline
organ
i had slappers on a 340 duster that worked GREAT. the only reason i removed them was a peace officer took exception to them. he said (and this is the absolute truth), "they're too low. you'll get a flat tire, the bar will dig in to the pavement, you'll lose control, and be killed." ok.
Re: Final Showdown: traction bars - YES or NO? [Re: maximum entropy] #1223314
05/04/12 10:06 PM
05/04/12 10:06 PM
Slinger WI
MadMez Offline
MadMez  Offline
Slinger WI
I had traction bars on my Challenger. I swapped in a 340 and four speed in place of the 318 automatic. It wheel hopped like crazy before I put them on. Also with slicks at the track it would just dead hook from 4500 rpm. My car had the soft 318 suspension so it needed something and the traction bars were free.
Re: Final Showdown: traction bars - YES or NO? [Re: maximum entropy] #1223315
05/04/12 10:10 PM
05/04/12 10:10 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Thats exactly what happened to me.. minus the getting killed part
Re: Final Showdown: traction bars - YES or NO? [Re: DARTH V8Я] #1223316
05/05/12 11:35 AM
05/05/12 11:35 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
No problem on my cuda. bracket is about even with the bottom of the rim. So the pavement will slightly hit the rim before the caltrac bracket. That would be after the tire shreds from the rim. Am going for the mono leaf springs and shock when i get the moola. Now have hemi rear leaf springs.
Re: Final Showdown: traction bars - YES or NO? [Re: cudaboone] #1223317
05/05/12 03:37 PM
05/05/12 03:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went with the Cal-trak system and picked up 4 tenthes over the worn out s/s springs.They adjust so the launch stays straight.I have not tried preload yet because I'm so inconsistant.Maybe this year with the right carbs on it now I can really fine tune the rear suspension.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223318
05/06/12 03:20 AM
05/06/12 03:20 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
First, I think traction bars are meant to be used INSTEAD of Super Stock springs, not WITH them. The whole purpose of the extra leaves in the SS springs is to stiffen (and in some cases shorten) the front segment to try to reduce wrap-up/wheel hop, which they do at the expense of ride quality. Clamping the front segments along with the use of properly installed traction bars will eliminate wheel hop and increase traction without stiffening the ride.
As to the snubber, while it does a limited job of eliminating front segment wrap-up, especially if the front segments are clamped, they do NOTHING to prevent the axle rotation from trying to pick up the passenger side tire. This is not the ring gear trying to climb the pinion; this is the ring gear trying to rotate around the pinion, which tries to pick up the passenger tire ( the reason why open carriers always spin only the right tire). Slapper bars can be pre-loaded to give more lift to the passenger side.
Slapper bars got a bad reputation from poor installations and a lack of knowledge about suspension engineering - pure and simple. With a little work they can do a fantastic job of stopping wheel hop and enhancing traction.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Final Showdown: traction bars - YES or NO? [Re: nutso suave] #1223319
05/06/12 04:14 AM
05/06/12 04:14 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Lots of options,but YES traction bars can work well on a mopar. I have used the south side machine bars for years on a low 10's 130mph car and even a high 10's 123mph street pick up truck. You could build your own or buy a set off ebay for a few $$ and with a bit of shock tuning you'd be set. There are other good choices but for a bang for the buck setup they can be very effective.
