Burnout Procedure with Transgo TF2? #1222690
04/26/12 06:30 PM
04/26/12 06:30 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
What's the proper burnout procedure for a car with a 727 and Transgo TF2 shift kit? I've been reading these things online that say to never start a burnout with a car with a 727 in first gear or else you risk the dreaded sprag failure/exploding 727/loss of foot/etc...
But with a stock automatic valve body isn't my only choice to start in first gear? Because no matter if I put the selector in 1,2, or D I'm gonna be starting out in first right?
Thanks for any advice!
Re: Burnout Procedure with Transgo TF2? [Re: 67Satty] #1222691
04/26/12 06:56 PM
04/26/12 06:56 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
a manual vb would be the best thing to have. u could try shifting with low tire spin. line pressure will be low & it may short shift for u, then u can wack on it & finish ur burnout.
Re: Burnout Procedure with Transgo TF2? [Re: rickraw] #1222692
04/26/12 07:07 PM
04/26/12 07:07 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
yeah, I have always started in 2nd or 3rd with a manual vb. But I think the big issue was back in the day, guys would yank the car into first coming out of the burn out box.
I agree with rickraw, just don't jump on the thing in the box, shift it through the gears easy.
I am no tranny expert though I asked a pretty beginner question earlier this week reguarding transmissions.
-Kenny
Re: Burnout Procedure with Transgo TF2? [Re: 67Satty] #1222693
04/26/12 11:37 PM
04/26/12 11:37 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
My trans has the TF2 shift kit. I simply set the line lock, pull the trans into drive, give it a moment to make sure it's engaged in gear, then start the wheels turning. You just need to be sure you get the r's up fast enough to keep em turning when the trans upshifts. I drive out of the water with the trans in high gear. Please bear in mind that my car does not have a ton of power, so I'm not putting much stress on any driveline/trans parts.
Re: Burnout Procedure with Transgo TF2? [Re: cagebob1] #1222694
04/26/12 11:54 PM
04/26/12 11:54 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have a transgo kit 727. if yours is a rear band apply starting in low should be ok. mine is full manual done by a local guy that had a record holding a body in the 60s. he said to do the burnout starting in first. do not get carried away with rpms. take it to second doing the same thing just keep them smoking and do not do a look at me burnout. when enough smoke let off the roll controle and slowly get into the throttle as it hooks to clean them off. never do a burn out in drive. keep rpms sane never do a dryhop. and stop before the line to pull it in low and roll in low a foot or so to set the sprag. he said do this and it will hold the power.
i know someone who busted 3 727s in someones hemi in a year being a jackass in the waterbox just like he runs his car doing a look at me tire fry and busted 3 gm 400s in his chevy.
do what you want or what makes you feel good but mine is the same trans since 1995. it gets a blessing every couple of years or a engine upgrade.
this is the first year i will have non stock parts with a billet front drumb.
the 4.x arm with a diesel 2nd band. lupo 9"@5400 to 5600 flash
Re: Burnout Procedure with Transgo TF2? [Re: dmking] #1222695
04/27/12 02:20 AM
04/27/12 02:20 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I guess I just don't understand this "set the sprag" therory
Re: Burnout Procedure with Transgo TF2? [Re: 67Satty] #1222696
04/27/12 11:10 AM
04/27/12 11:10 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Stick it in L/1st and leave it there to keep the band applied. Otherwise you should switch to a full manual vb that allows you to start in 2nd.
Re: Burnout Procedure with Transgo TF2? [Re: dartman366] #1222697
04/27/12 06:17 PM
04/27/12 06:17 PM
Ambridge, Pa.
Ambridge, Pa.
Re: Burnout Procedure with Transgo TF2? [Re: BradH] #1222698
04/27/12 06:59 PM
04/27/12 06:59 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
This is not what TransGo says. I too have a TF-2 kit, and after reading all the horror stories on this sight about blowing up your tranny in the burnout box, I called transgo and asked them. The tech guy there (forget his name but he knew his stuff) said that the exploding sprag theory with 727's only applies to manual valve bodies that do not include a low band apply feature (I can't figure out why many of the MVB's are built like this, but apparently they are). The TF-2 (and TF-3 manual) kits DO apply the low gear band when in manual low, so you are not at risk of scattering the sprag. He said you are fine to start in low and then shift to 2nd once you get the tires up to speed. This was a direct conversation between myself and Transgo.
Re: Burnout Procedure with Transgo TF2? [Re: StealthWedge67] #1222699
04/27/12 11:17 PM
04/27/12 11:17 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
if the sprag fails the front drumb goes either twice the engine rpms or it goes even higher than twice.that what makes them blow up.
the setting the sprag thing does not make sence with the low band applyed but then my feet are involved i tend to be extra carefull and if it only makes sence for a non rear band apply i can do it anyway.
Re: Burnout Procedure with Transgo TF2? [Re: dmking] #1222700
04/28/12 12:05 AM
04/28/12 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
2.2 times engine RPM... centrifugal force causes
the explosion... but the stock drum can take about
11,000 rpm before it comes apart so anything above
about 5200 rpm and its a problem(if the sprag fails)
I dont run a low band apply VB but I dont do stupid
stuff that will blow it
Re: Burnout Procedure with Transgo TF2? [Re: MR_P_BODY] #1222701
04/28/12 01:17 AM
04/28/12 01:17 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I have a Copes Trans with billet front drum, TF-2, and it's still a full auto trans. He told me shift into 1st. Get some smoke, then into second.
Re: Burnout Procedure with Transgo TF2? [Re: 67Satty] #1222702
04/28/12 02:57 AM
04/28/12 02:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I always thaught trans-go was not the hot set up........ Had their shift kit years ago and it sucked and had a TON of overlap on the 2nd to 3rd shifts then I got the cheeta non low band apply and never looked back. You mean fast cars run that stuff?
Re: Burnout Procedure with Transgo TF2? [Re: Thumperdart] #1222703
04/28/12 12:08 PM
04/28/12 12:08 PM
Puyallup, WA
Puyallup, WA
I could be wrong, but I've been told that the 2-3 overlap can be affected by how well the valve body kit was installed. I guess I'm unsure of WHY you would want a valve body that did NOT apply the low gear band, when in low gear??? Please explain.
Re: Burnout Procedure with Transgo TF2? [Re: StealthWedge67] #1222704
04/28/12 01:02 PM
04/28/12 01:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the arm 5.0, 4.2, 3.8 will dictate the over lap..
how fast they apply
When I bought my VB there wasnt a low band apply
and I dont feel like spending $550 -$600 for a new one
Re: Burnout Procedure with Transgo TF2? [Re: MR_P_BODY] #1222705
04/28/12 01:21 PM
04/28/12 01:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
how fast they apply
Exactly, when I bought my vb that`s all they offered and I`ve NEVER hurt the trans or anything for that matter and it`s been rebuilt several times over the years.........maybe not as safe as some have stated but it stays for now just like the stock main caps in my motor and in the 8 3/4...........
Re: Burnout Procedure with Transgo TF2? [Re: MR_P_BODY] #1222706
04/28/12 01:23 PM
04/28/12 01:23 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Yeah, I haven't noticed any 2-3 shift overlap problem with my Transgo TF2 shift kit. I think I have the 4.2 arm but can't remember for sure. Anyway, the shift from 2-3 is VERY firm and RIGHT NOW.
But if I had to do it over again I'd probably go for a manual reverse pattern valve body and aftermarket shifter but I was putting this thing together on a budget and I wanted to keep the stock shifter and console look.
Then again, before I spend a bunch more money on more 727-related stuff, I think I will just convert to a 4 speed. Now, that would be fun!
Re: Burnout Procedure with Transgo TF2? [Re: 67Satty] #1222707
04/28/12 01:27 PM
04/28/12 01:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin back I did run the 5.0 arm and Pro Trans put in a 4.2 iirc...................
Re: Burnout Procedure with Transgo TF2? [Re: Thumperdart] #1222708
04/28/12 04:42 PM
04/28/12 04:42 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Just put it in drive give it gas, make sure it shifts to second and come out of the water.. Did it for 4 years in mine while I put in a manual vb and its an old turbo action that's non low band apply.. And its the same trans that's been in my car from day one.. I don't even know how many passes it has on it..
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Burnout Procedure with Transgo TF2? [Re: kissmyaspen] #1222709
04/28/12 06:01 PM
04/28/12 06:01 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
I just installed TF-3 Transgo kit in a TF999... it previously had a manual vb,I grab a old valve body and insstalled the TF-3 and 5600 govenor.Was I impressed,it shited like a good 727 and when you shifed it manually
I thought it was a manual vb!!The auto shift was 5200? DM
