ShoGun water pump system users? !!! UPDATE!! #1222506
04/26/12 09:05 AM
04/26/12 09:05 AM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Anyone here use these... The lines sure are small, but this setup is defintaly light weight. If I was running alky with this car, no question it would work..
But will it keep my race car cool between rounds, in the Kentucky heat & Humidity?
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222507
04/26/12 09:51 AM
04/26/12 09:51 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
are you using both the pump and manifold?if so the manifold has #8 fittings correct?[in/out]i just have the manifold but have not used it.
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222508
04/26/12 11:43 AM
04/26/12 11:43 AM
Western Kentucky
Muscles Offline
Muscles  Offline
Western Kentucky
I've used one for years with no problems.
Re: ShoGun water pump system users? [Re: Clanton] #1222509
04/26/12 11:49 AM
04/26/12 11:49 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Bill @ Sho-Gun says the lines are small for a reason. I use a Sho-Gun cooling system but changed to a bigger pump(I had the small Sho-Gun pump)only because the Sho-Gun pump went out. Sho-Guns bigger pump or a after market pump dose seem to work better. But I cheated and used the #10 lines with reducers at the manifold. Try it I think you will be pleased!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: ShoGun water pump system users? [Re: MRMOPAR622] #1222510
04/26/12 11:51 AM
04/26/12 11:51 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i hope to use it with a wp136.
20 GPM
http://www.jegs.com/i/Meziere/680/WP136S/10002/-1
Re: ShoGun water pump system users? [Re: Clanton] #1222511
04/26/12 01:54 PM
04/26/12 01:54 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
you can get a spare pump here... make sure to keep a couple spare impellers on hand and use some kind of cooling system lubricant...
http://www.starwatersystems.com/ProductBenefit.aspx?ProductID=199
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: ShoGun water pump system users? [Re: StripeHOG] #1222512
04/26/12 02:21 PM
04/26/12 02:21 PM
That looks like the pump that I got at Harbor Freight to replace my leaking Borba pump on a Saturday morning. It is a little noisey but I haven't had an overheating problem yet.
Re: ShoGun water pump system users? [Re: ] #1222513
04/26/12 02:35 PM
04/26/12 02:35 PM
Here are some pctures of my Shogun pump and why I wasn't impressed with it.
I don't understand why the holes are so small for the imput and output, when compared to the 3/8 line size going to it. Then on to a split manifold after that(more volume).
Re: ShoGun water pump system users? [Re: ] #1222514
04/26/12 02:59 PM
04/26/12 02:59 PM
The reason I didn't like the pump and didn't use it was because the lines were a pain to install.
You can see the holes for the lines were drilled verticle to the two button head screws on the top and bottom of the pump. I guess the reason being, you could then drill both verticle holes without moving the drill head. If the holes were drilled at a few degrees the lines would be easier to install. I think they should be drilled perpendicular to the pump head.
This is the problem it causes when your intalling the lines. Maybe someone out there can explain why you would design a race part like this.
Re: ShoGun water pump system users? [Re: ] #1222515
04/26/12 04:28 PM
04/26/12 04:28 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
I've used one for over 5 years with no problems. Bought a spare impeller just incase, but haven't need it. My only complaint is that it's noisey.
Re: ShoGun water pump system users? [Re: Gearhead383] #1222516
04/26/12 08:08 PM
04/26/12 08:08 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
more than 10 years no problems. Bill says he uses -8 lines because the block passages are 1/2 inch.
Re: ShoGun water pump system users? [Re: evenflow] #1222517
04/27/12 12:17 AM
04/27/12 12:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ran one on my RB equipped Mirada for years. In the Vegas heat you could go round after round with no issues. Cooled to the point where you could take your sweet time in later rounds while the other guy was puking coolant after the his burnout... DAMHIK
Re: ShoGun water pump system users? [Re: J_BODY] #1222518
04/27/12 12:38 AM
04/27/12 12:38 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the shogun pump blows. I use a booster pumpoff a school bus. Part# CP-20-BBWA
Joe
Without Data, you’re just another guy with an opinion.
Re: ShoGun water pump system users? [Re: ] #1222519
04/27/12 10:51 PM
04/27/12 10:51 PM
Rock Springs
Rock Springs
Not sure why that you didnt fix that... Could have used a street L or just a short nipple, then ordered a fitting with a female end? 100 ways to get around that little set back... anyways...
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222520
04/28/12 10:36 AM
04/28/12 10:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Interesting.... my pump was set up in the same fashion, but I didn't have an issue putting the lines on like your pict clearly shows. Drill must have been off an "n'th" the day that one was made.
Re: ShoGun water pump system users? [Re: J_BODY] #1222521
04/28/12 11:33 AM
04/28/12 11:33 AM
You can't tell the centerline from a picture I lifted from the Shogun site. I still don't understand why they don't just drill a few degrees off center so they will clear. The added clearence would make it easier to work on when your hanging over a fender.
I guess having made my own cooling system and worried about things like clearences When you maufature a product I think you would make it as adaptable as possible.
Re: ShoGun water pump system users? [Re: ] #1222522
04/28/12 01:11 PM
04/28/12 01:11 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Anyone, besides Bob (eh100), made their own manifolds? If so, do you have any pictures?
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: ShoGun water pump system users? [Re: MRMOPAR] #1222523
04/28/12 01:47 PM
04/28/12 01:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
AndyF i believe makes some.
Re: ShoGun water pump system users? [Re: MRMOPAR] #1222524
04/28/12 02:18 PM
04/28/12 02:18 PM
AndyF Offline
AndyF  Offline
Yes, I make water manifolds for BB and Hemi engines.
http://www.hughesengines.com/Index/produ...mp;partid=27040
Re: ShoGun water pump system users? [Re: Bob_Coomer] #1222525
04/28/12 02:46 PM
04/28/12 02:46 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Any of you guys pump water through the heads? I can't use the front top engine hole because the heads don't have a water provision(hole). I have to use the front(and rear) of the heads(core holes)
I was trying dif. combos here....
