Firecore RTR distributor results inside
#1221871
04/24/12 09:35 PM
04/24/12 09:35 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I have been dyno testing a lot of different ignition components lately on one of my engines. The latest testing was done on a Firecore ready to run distributor along with their matching coil. I did some back to back testing of this setup versus the MSD 6 and a matching Blaster 2 coil. I also need to thank Rich @ Firecore for loaning a couple of other coils to me for testing purposes.
The results pretty much speak for themselves. The Firecore setup ran as good as and at many points over the rpm range,actually surpassed the MSD system. I will be testing the Firecore setup against the MP Chrome box in the next day or so,but I can tell you that in some of my previous testing,the MSD outshined the Chrome box everyrwhere. So if history repeats itself,the old MP will be outdone again.
Keith
Re: Firecore RTR distributor results inside
[Re: Dunnuck Racing]
#1221873
04/24/12 09:52 PM
04/24/12 09:52 PM
Dunnuck Racing
Northern Indiana
Last sheet for now. I should note,the HVC 2 Rich loaned me was the other test. It is supposed to be a better coil than the Blaster 2 for this ignition. It actually was nearly the same in this application.
#1221874
04/24/12 09:58 PM
04/24/12 09:58 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have the race mechanical unit in my 493 and I loved it the minute I bolted it in I was able to set the advance curve that I needed within minutes and it is rock steady timing Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: tboomer]
#1221876
04/24/12 10:11 PM
04/24/12 10:11 PM
Dunnuck Racing
Northern Indiana
Hi Ted!, I did play with the timing,and if it were not for my lack of hi speed internet,I would post a lot more. With both ignitions it basically had the same results with less timing,but the power fell off everywhere. I also tested the HVC coil against the Firecore with his distributor. The Firecore ran better in all but one of the tests. I think that one was a fluke,because repeating the test a few more times the Firecore consistently outperformed it. Keith
#1221878
04/24/12 10:51 PM
04/24/12 10:51 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Try a Mopar Gold Box instead,I'll bet it won't surpass that.
[Re: Chris2581]
#1221879
04/24/12 11:03 PM
04/24/12 11:03 PM
Dunnuck Racing
Northern Indiana
I would be glad to test one,if you send me a good one. Several years ago I tried getting a Gold Box for one of my bracket cars. I went through a couple of them and could not get one that would work. I figured it was a wiring issue,went through the MP manual about wiring it,and had a friend try them in his car that ran a gold box. Would not work in his car either. This was back around the time people were having issues with orange boxes so that might have something to do with it. I have been running an Accel digital ignition in my car the last several years,I am not a fan of MSD and all the hassles people have with them. I am working on testing several different ignition sytems to decide what I think is the best for the money. I would be glad to try another gold box,but I won't spend money on one after the results I had before,there are too many other options. Keith
[Re: davenc]
#1221881
04/24/12 11:31 PM
04/24/12 11:31 PM
Dunnuck Racing
Northern Indiana
Yes,the MSD box was not happy at all with it. Sounded like it was on a rev limiter before it got to 2000 rpm. I would have to let Rich explain it,I can only guess that the Firecore system has a long hot spark and and the coil won't take quick short spikes like the MSD. But as I said,that is purely speculation on my part from what I have seen happen with some other combinations. Keith
#1221883
04/25/12 12:05 AM
04/25/12 12:05 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Am I seeing that correctly???? what gives with the numbers at 6400 and 6500? The Firecore stuff is leading by 11 hp then at 100 more rpm its magically gives up 14 HP? The numbers look crazy, they loose at one rpm, and gain by the same diff the next. Im not debating the FireCore Stuff is good quality. again 4200 and 4300 rpms?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: sunroofgtx]
#1221884
04/25/12 12:10 AM
04/25/12 12:10 AM
Dunnuck Racing
Northern Indiana
Thanks Rich,I will check it again. I tested a few different coils with both ignitions. I will be doing some more testing in another day or so. I will let you know what happens then. I did remember you telling me the coil would not work with the MP ignitions and would kill the MP box,so when I thought there was a problem with it on the MSD I just pulled it off.
Keith
[Re: Bob_Coomer]
#1221885
04/25/12 12:29 AM
04/25/12 12:29 AM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello, I was wondering if those number irregularities were dyno issues. Damon
#1221890
04/25/12 12:57 PM
04/25/12 12:57 PM
Bob_Coomer
Rock Springs
Sorry for the Hijack but I need: Fire Core offer a coil for the MSD 7AL series? Doesnt seem like there is many options.. More or less the MSD Prfo power, or the HVC? Not sure what I need, but need one that will work for my old reliable MSD 7AL-3???
