what color should my 71 340 motor be? #1221827
04/24/12 08:26 PM
04/24/12 08:26 PM
MILFORD, MICHIGAN
MILFORD MOPARS Offline OP
MILFORD, MICHIGAN
got a fresh small block ready for paint
its a # matching block.built early in 71
not sure if they were orange or blue???
Re: what color should my 71 340 motor be? [Re: MILFORD MOPARS] #1221828
04/24/12 08:45 PM
04/24/12 08:45 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
.built early in 71
Orange.
Re: what color should my 71 340 motor be? [Re: formula_s] #1221829
04/24/12 09:14 PM
04/24/12 09:14 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
What is the approximate date of the color change to blue?
Is it just color or was there a Hp change as well?
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: what color should my 71 340 motor be? [Re: BS27R1B] #1221830
04/24/12 10:31 PM
04/24/12 10:31 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think March/April was the color change.
Re: what color should my 71 340 motor be? [Re: burdar] #1221831
04/24/12 11:34 PM
04/24/12 11:34 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There is no known exact color change date but it was sometime from March to April of 1971. There was no HP change but some engine parts changed at either the same time or close to the same time. Passenger side valve cover went to a small 318 style center wire harness hold down from the previous wide version. Intake casting was the same number but a different casting which had new physical features, some (or all) negative battery cables were getting painted with engine color (so far all I've seen are previously bare in 71). Late (LATE) production cars could have electronic ignition. There were likely other small details that have yet to be recognized, it's a puzzle that is still not completely solved.
Re: what color should my 71 340 motor be? [Re: MILFORD MOPARS] #1221832
05/15/12 12:03 PM
05/15/12 12:03 PM
fiddlerfingers Offline
Just a FYI there is 2 different color orange paints for Mopars. Your 340 will need "Street Hemi Orange" to be correct, not "Race Hemi Orange". Also the small hose between the intake and water pump should be installed before painting and recieve over spray to achieve the factory look.
