Smith Brother pushrods #1221566
04/24/12 11:57 AM
04/24/12 11:57 AM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Just receive my Special order pusrods...
Perfect fit.
Only one threads showing on adjuster.
Thanks Smith Brother
Re: Smith Brother pushrods [Re: STROKIE] #1221567
04/24/12 12:03 PM
04/24/12 12:03 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
With a little bit of luck.. within 2 weeks I'll be placing an order with them for my newest build..
Re: Smith Brother pushrods [Re: STROKIE] #1221568
04/24/12 01:23 PM
04/24/12 01:23 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I am a firm believer in the Smoth Brother's product! I had a rocker that wasn't oiling, and it ate the end of one of my Smith Bro's push rods. They were 5/16" diameter. I had a set comp 3/8" push rods the right length, so I put one in to replace the Smith Bro one that had the end eaten off. One run up to 6000rpm on the dyno, and the comp push rod just wrinkled.
-Kenny
Re: Smith Brother pushrods [Re: StrokerAspen] #1221569
04/24/12 06:12 PM
04/24/12 06:12 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Fast, friendly service and a product that is the preverbial "anvil in the desert". What more could you ask for?
Yeah, it's got a smallblock.
Re: Smith Brother pushrods [Re: 340B5] #1221570
04/24/12 06:53 PM
04/24/12 06:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You need to thank yourself for giving them the correct measurements. I hear all good about them. I used Manton which work good also and gave me great service. Ron
Re: Smith Brother pushrods [Re: 383man] #1221571
04/24/12 08:28 PM
04/24/12 08:28 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I run them in my 572 and did run them in my 446 & 452 with (NO TROUBLE) that`s the only pushrod i will buy and they will help you out if you need them fast they are good people to buy from
Re: Smith Brother pushrods [Re: steeldust] #1221572
04/24/12 11:43 PM
04/24/12 11:43 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Absolutely a great company to work with. Beep
Re: Smith Brother pushrods [Re: Bigbeep] #1221573
04/25/12 01:28 AM
04/25/12 01:28 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I have a massive set of them in my silly street driven toy. The talk of Smith Bros on this forum was enough for me to want them... overkill x100, but I wanted them, haah!
Re: Smith Brother pushrods [Re: redmist] #1221574
04/25/12 01:08 PM
04/25/12 01:08 PM
dogdays Offline
dogdays  Offline
Plus, they make great cough drops! I hope their long, fluffy beards don't get caught in the machinery.
R.
Re: Smith Brother pushrods [Re: dogdays] #1221575
04/25/12 02:59 PM
04/25/12 02:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
I must be the one that Murphy loves, I've had multiple problems with Smith Bros pushrods, breaking, burning up thier pushrods and adjusters and so on I am a dealer for both Mantons and Smith Bros, I'll only use Smith Bros products on flat tappet cams when the customer insist on them, every thing else gets Mantons
Re: Smith Brother pushrods [Re: Cab_Burge] #1221576
04/25/12 03:27 PM
04/25/12 03:27 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I love My smithys, After a number of issues getting the CORRECT length from you know who, I finally ate the big bullit, called Dan at perf only, he got me the Correct length the first time, and the smith bros are also a perfect fit. Didnt mind the manton stuff, but man oh man what a disaster getting them the correct length, but that wasnt entirely their own fault.
Re: Smith Brother pushrods [Re: Moparnut426] #1221577
04/26/12 12:08 PM
04/26/12 12:08 PM
organ
maximum entropy Offline
organ
looks good! now, get rid of those shims!
Re: Smith Brother pushrods [Re: maximum entropy] #1221578
04/27/12 12:03 AM
04/27/12 12:03 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I'm more than happy with mine too. And the customer service.
Word of advice for anyone ordering custom sizes.
ORDER AN EXTRA OR TWO!!
Never know when you'll need one, and being a custom size, your chevy buddy probably won't have a spare.
codfish
Re: Smith Brother pushrods [Re: STROKIE] #1221579
04/27/12 01:05 AM
04/27/12 01:05 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The number of threads showing isn't the whole picture - it's just easy to remember.
Depending on the design, the ball may have considerable stem length before the thread starts (as yours shows). Here, the shortest practical length (leaving some wiggle room for wear) is the height of 1-2 threads (not actual threads) below the rocker, if that lets the cup clear the body. If you have 3/8-24, 2 threads is about .083", much closer to the rocker than you show - which raises the ratio.
Note: it's also helpful to have enough thread showing to release the pushrod, which means (roughly) the ball radius.
I would guess he did the geo and saw that a shim was a needed correction. If yes, it's still needed (although I'd prefer a shim under the pedestal).
Boffin Emeritus
Re: Smith Brother pushrods [Re: polyspheric] #1221580
04/27/12 06:54 AM
04/27/12 06:54 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Long ago I started to seat new pushrods to new adjusters to insure a near perfect fit in the cups. I put the adjuster in a drill press and apply some valve grinding compound in the cup. Spin the drill and you can see the exact area of contact gain in size. what you want to see is a nice wide band of contact. The two stay as a pair after that.Why and what happens when this is done ? When you make some pulls or passes and go back for that final adjustment check there will be little or no change in lash that got larger that you normally would see .
home of the
Sox and Martin Hemi Duster
Re: Smith Brother pushrods [Re: HEMIFRED] #1221581
04/28/12 12:59 AM
04/28/12 12:59 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Good idea Fred
codfish
Re: Smith Brother pushrods [Re: maximum entropy] #1221582
04/30/12 07:41 PM
04/30/12 07:41 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
I used shims to correct the geometry.
I'm not an expert but I tried with the knowledge I have to build the best motor I can.
With the shims I can correct the geometry.
May be more expensive solution but I can't afford it
See actual pattern geometry...
Re: Smith Brother pushrods [Re: STROKIE] #1221583
05/01/12 01:03 AM
05/01/12 01:03 AM
New York, USA
Chargerfan68 Offline
New York, USA
Nice work...looks like very good geometry.
Good luck with the engine!
