Thermoquad Accelerator Pump? #1221454
04/24/12 05:42 AM
04/24/12 05:42 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Im getting just a slight hesitation when Im starting out from a stop light. Seems like the car wants more gas. This hesitation is slightly felt when I shift into second gear as well. Is this an accelerator pump issue? If so? How can this be adjusted out? This freshly rebuilt motor has about 100 miles on it so far. If not the accelerator pump any other suggestions for adjustment?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Thermoquad Accelerator Pump? [Re: 19cuda73] #1221455
04/24/12 09:56 AM
04/24/12 09:56 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Sounds more like your secondary air door needs adjustment.
Re: Thermoquad Accelerator Pump? [Re: ScottSmith_Harms] #1221456
04/24/12 01:54 PM
04/24/12 01:54 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
you should be able to change the hole/slot in lever or bend the link for more stroke, maybe a tad more timing
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Thermoquad Accelerator Pump? [Re: 440lebaron] #1221457
04/25/12 02:12 PM
04/25/12 02:12 PM
germany
440sat72 Offline
440sat72  Offline
germany
Maybe this will help ... the pictures are gone, though - maybe you can contact NachoRT74 wether he still has them ...
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
