Internal clearance w/ 4.500 std journal 2.375? crank
#1220953
04/23/12 08:18 AM
04/23/12 08:18 AM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
I'm looking at a crank which has 2.375 rod journals & 4.500 stroke .. I plan to use Oliver rods & was wondering if there enough rotating assembly clearance inside a KB street hemi water block for this combo. Potential probs with cam lobe interference w/ roller cam .? The crank looks like a good deal so just wanted to make sure... I was originally planning on 2.200 journals but this crank looks good . Darren
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: Internal clearance w/ 4.500 std journal 2.375? crank
[Re: Keith Black®]
#1220954
04/23/12 05:04 PM
04/23/12 05:04 PM
Keith Black®
QLD Australia
...any experience with this would be helpful!
[Re: Keith Black®]
#1220955
04/24/12 07:50 AM
04/24/12 07:50 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have run a 4.5 crank, 2.375 bearings on the rods using a Cam Dynamics roller with 286 @ .050 intake/exhuast duration, .500 lobes. This was in a stock factory block. I have no reason to think any other block would have a problem running this combo, provided the rods are steel and about the same thickness at the rod bolt to cam interference point is the same.
[Re: gregsdart]
#1220958
04/24/12 09:41 PM
04/24/12 09:41 PM
Keith Black®
QLD Australia
thanks for this .looks like KB may be able to notch the block a little as part of my order , no major issues as far as i can tell. as to cam interference I'll have to take the risk but I'm not going to be running a huge cam (250/262 @ 0.050 + 0.700 @ valve ). Standard cam location roller .I'm sure others have run similar combos without problems.
