What causes high NOX readings? FOLLOW UP
#1220398
04/22/12 10:37 AM
04/22/12 10:37 AM
Posts: 16,842 Between Houston & Galveston TX
SattyNoCar
As usual, my '93 Caravan has failed emissions due to high NOX readings. I've owned this van 2 yrs, this will be the third inspection its had in my ownership. First inspection, oxygen sensor WAS bad, replaced it and had a new (universal) cat installed......passed inspection. Second inspection, failed again, replaced cat under warranty......passed inspection. Now during this whole time, the van seemed to be running a little 'rich'. I finally fixed that issue recently. Which brings us to the third inspection which it has failed again for the same reason with almost the same numbers. Did I kill the convertor (again) running it 'rich' until recently? Do I need to step up to a better (not universal) convertor? Or, do I need to look somewhere else for the problem? This is really chapping my butt because the thing runs so good. Before this, I had a '91 Ramcharger that was a gas sucking, oil burning pig, and it passed emissions with flying colors. Aside from replacing the cat again, I'm at a loss here. ![](/ubbthreads/images/graemlins/shruggy.gif)
John
Re: What causes high NOX readings?
[Re: Dcuda69]
#1220400
04/22/12 12:07 PM
04/22/12 12:07 PM
SattyNoCar
Oh yeah, forgot to mention, this thing DOES NOT have an EGR valve on it. Got into it with the guy at the inspection station about it too. The block off plate has a factory looking number on it, and the vacuum line routing decal underhood doesn't even show the EGR. ![](/ubbthreads/images/graemlins/confused.gif) All I can tell you about the cooling system is that it doesn't overheat. I kinda went with the (cheaper) universal cat because I didn't know if this van would last another year (when I first got it). Thanks for the reply. ![](/ubbthreads/images/graemlins/beer.gif)
John
[Re: SattyNoCar]
#1220401
04/22/12 12:49 PM
04/22/12 12:49 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Put in a few gallons of e-85, that will bring the NOX down real nice, it will even help with HC and CO.
[Re: Twostick]
#1220403
04/22/12 01:15 PM
04/22/12 01:15 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I had a Spirit with a 3.0 that I used to get to pass by gassing up with premium before testing. Premium burns slower so it's a little cooler burn which lowers your Nox. The downside is that it will drive up your HC so you have to be low in that dept.
Kevin
I've also done this twice with my '95 Dakota 5.2 after it repeatedly flunked Nox. Run a tank of CRC "Guaranteed to Pass", then fill with premium and go take the test. Worked for me both times.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: SattyNoCar]
#1220404
04/22/12 01:20 PM
04/22/12 01:20 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
The cheaper cats do not last very long, to the point in California the CARB outlawed the sale of cheap Cats and had them pass a test before they can be sold to a person in California.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#1220405
04/22/12 03:49 PM
04/22/12 03:49 PM
SattyNoCar
Oops, forgot to mention its the 2.5 four banger...... No E85 around here (that I know of), so, scratch that. I can do premium though. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Interesting tidbit about CA outlawing cheap cats, didn't know that. ![](/ubbthreads/images/graemlins/beer.gif)
John
[Re: SattyNoCar]
#1220407
04/23/12 01:02 AM
04/23/12 01:02 AM
HotRodDave
Kalispell Mt.
Denotured will work just the same. Don't leave a bunch of it in the tank for a long time, it is more corrosive than ethanol.
[Re: Hotwheelsjr]
#1220409
05/06/12 06:32 PM
05/06/12 06:32 PM
SattyNoCar
Well, I didn't try the heet, but, I put about 10 gallons of premium in. I drove the van 50 miles and took it straight to the emissions testing. It failed AGAIN. But, for a different reason. HC and CO was way up. NOX dropped to well within the legal limit. Could it still be the convertor? I'm about ready to throw a match on this thing. ![](/ubbthreads/images/graemlins/smilie_help.gif)
John
[Re: RodStRace]
#1220412
05/07/12 06:29 PM
05/07/12 06:29 PM
SattyNoCar
Something has happened. Fired it up this morning, and it was chuggin' and left black soot on the driveway. It was fine before. Let me check a few things before I post readings. ![](/ubbthreads/images/graemlins/flame.gif)
John
