Driver side axle won't go in! #1220196
04/21/12 11:08 PM
04/21/12 11:08 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Fresh rebuild for an 8 3/4 rear in a 70 B Body. Driver side axle bottoms out about 1/4 inch out. Never had problems with this in the past so am looking for any thoughts as to what it might be before I pull the punkin back out. Does it regardless if the passenger side is in or not.
Any help is appreciated.
Thanks in advance!
Re: Driver side axle won't go in! [Re: slowpoke] #1220197
04/22/12 12:20 AM
04/22/12 12:20 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you have a clutch type differential , there is a centering button that can fall out of place in the center of the differential and cause your problem.
sometimes you can use a long magnet and put it back in position. Worse case, you must pull the center section, reposition it and reassmeble.
Pull the axle and take a look at it.
Re: Driver side axle won't go in! [Re: slowpoke] #1220198
04/22/12 12:51 AM
04/22/12 12:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Another possibility if it a OE locking diff of either design the splines between the side gears & the locker may be mis-aligned... Try locking the passenger side axle, bolt a wheel but no brake drum to the drivers side axle, grab the wheel & rock it back & forth while pushing in... Often the splines will shift slightly & the axle will slide in...
Re: Driver side axle won't go in! [Re: slowpoke] #1220199
04/22/12 08:52 AM
04/22/12 08:52 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
If you changed from the stock caged bearings and adjuster to the "green" bearings, you may have to remove the centering button from the differential.
Re: Driver side axle won't go in! [Re: 1_WILD_RT] #1220200
04/22/12 09:07 AM
04/22/12 09:07 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks for the replys! I had done the alignment thing you describe previously and it allowed it to go in from about 3/4 of an inch to the current 1/4. Can't really tell but the button appears to be ok as we'll. Going to take some measurements to try to verify. Btw it is a factory diff no green bearings.
Thanks again!
Re: Driver side axle won't go in! [Re: slowpoke] #1220201
04/22/12 10:50 AM
04/22/12 10:50 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Did you try backing the adjuster off on the passenger axle?
Re: Driver side axle won't go in! [Re: 1_WILD_RT] #1220202
04/22/12 09:40 PM
04/22/12 09:40 PM
Central New York
bfury Offline
bfury  Offline
Central New York
Back off the adjuster, that's the answer.
No Stock
Re: Driver side axle won't go in! [Re: slowpoke] #1220203
04/22/12 11:34 PM
04/22/12 11:34 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Got it!!! After measuring both sides i found the button locked to the left. Apparently it cocked just enough that when I pushed the axle in it wedged it tight. I was able to take a broom handle and tap around on it and it finally get it freed up. Both axles slipped right in and adjusted out fine. Thanks to everyone for their advise!
Re: Driver side axle won't go in! [Re: slowpoke] #1220204
04/23/12 12:51 AM
04/23/12 12:51 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Good job.
Now show us some burn out pics
codfish
Re: Driver side axle won't go in! [Re: codfish] #1220205
04/23/12 10:25 AM
04/23/12 10:25 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks, will do!
Re: Driver side axle won't go in! [Re: slowpoke] #1220206
04/23/12 04:26 PM
04/23/12 04:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
One last question. Did you hand pack the axle bearings. They are not lubricated by the rear end lube.
