Re: How to remove the heater hose pipe from WP housing?
[Re: JoesMopar]
#1220004
04/21/12 09:29 PM
04/21/12 09:29 PM
Posts: 1,357 central Florida
VL21
central Florida
It's been a while, but I just used to turn the bolt out, it sort of acted as a puller for the housing, take things off as an assembly, clean things up, re-assemble the reverse, no need to remove nipple. Probably I am just lazy...OK, no probably about it...
It takes gasoline to interest me.
[Re: JoesMopar]
#1220008
04/22/12 02:40 AM
04/22/12 02:40 AM
Posts: 2,874 Upstate, NY
sixpack4spd
Upstate, NY
Step 1. Buy new pipe Step 2. Destroy old one trying to get it out. Step 3. Install new pipe I've never been able to get one out without destroying it...
[Re: sixpack4spd]
#1220009
04/22/12 07:48 AM
04/22/12 07:48 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
I agree you will need heat.Ive never taken one out without using heat.Ive also pulled a bunch without taking the pipe out.Just get all the bolts out.Leave a long one in just as a support.Then just turn the one out behind the tube.Its slow but they will come out.The bolt and pump will just keep going foward.Rocky
Chrysler Firepower
[Re: sixpack4spd]
#1220010
04/22/12 09:37 AM
04/22/12 09:37 AM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
Same here
[Re: therocks]
#1220011
04/22/12 11:43 AM
04/22/12 11:43 AM
Posts: 2,782 USA
JoesMopar
USA
I'm not taking the housing off, it doesn't leak. I'm taking the alternator bracket off and one of the bolts that holds it on is behind the pipe for the heater hose, so the bolt has to come out.
Going to try taking it today and see what happens....
[Re: bboogieart]
#1220013
04/22/12 12:10 PM
04/22/12 12:10 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Wish you good luck
hopefully he has stacked up alot of good points in the Karma collection!
[Re: JoesMopar]
#1220016
04/22/12 04:43 PM
04/22/12 04:43 PM
Posts: 26,544 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Shove a tapered pry bar or punch into the nipple hole to keep it from collapsing and then use a pipe wrench or big Vise-Grips to spin it out.
