MSD 6A OK #1219993
04/21/12 07:42 PM
04/21/12 07:42 PM
IN
ahy Offline OP
ahy  Offline OP
IN
My Challenger is acting up. It runs rough on moderate acceleration and sometimes pings under moderate load like one or more cylinders are advanced too much. It has the MP black "vibration proof" 6 analog box.
I'm getting ready to check it all out and wondered if these are symptoms of a faulty ignition box.
The box is triggered by the "points" wire from an XFI box.
Re: MSD 6A Dying? [Re: ahy] #1219994
04/21/12 08:31 PM
04/21/12 08:31 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I wouldn't think so.
It's Swifty! Swifty, you toad sucker!
Re: MSD 6A Dying? [Re: zrxkawboy] #1219995
04/21/12 09:45 PM
04/21/12 09:45 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
When my last 6a died it died dead no whimpers first. Did you check for fouled plugs?
Re: MSD 6A Dying? [Re: radar] #1219996
04/21/12 09:52 PM
04/21/12 09:52 PM
IN
ahy Offline OP
ahy  Offline OP
IN
I'll pull the plugs, inspect cap/rotor/wires and double check timing tommorrw. I've had worn ignition parts cause a miss, but never random pinging. That's what made me wonder about the box.
Re: MSD 6A Dying? [Re: ahy] #1219997
04/23/12 12:52 PM
04/23/12 12:52 PM
dogdays Offline
dogdays  Offline
As the MSD 6 responds to the trigger with a spark it is hard to see how a faulty one conld make a spark before the trigger event. It's not like late model engines that calculate the next spark based on crank position, at least that's my idea of how they work.
R.
Re: MSD 6A Dying? [Re: dogdays] #1219998
04/24/12 09:18 AM
04/24/12 09:18 AM
tboomer Online work
tboomer  Online Work
Some good reading here about the MSD boxes..
http://classracer.com/classforum/showthread.php?t=37282
Re: MSD 6A Dying? [Re: tboomer] #1219999
04/24/12 10:40 AM
04/24/12 10:40 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Mine recently died, and it took out the coil first. It was very intermitent and it took a long time to find it. I also had a slight miss over the summer I couldn't find, but suspected the box. I have never liked the MSD6 boxes. I had a previous one that I replaced with a 7AL, and what a difference. This last one I replaced the MSD6 with a Crane Hi-6, and, again, what a difference. Throttle response, the way the idle is better and cleaner, amazing.
Re: MSD 6A OK [Re: Dragula] #1220000
04/27/12 11:31 PM
04/27/12 11:31 PM
IN
ahy Offline OP
ahy  Offline OP
IN
Fixed... it was a loose plug wire. Its running like it should now.
