From my '68 RR build sheet I can tell what it isn't and a little reverse engineering we can get close.
On my sheet:
Under the box labeled Wheel is 300
30 = 14 x 5.5 " Styled Road
0 = Color: chrome
Box labeled "wheel cover"
= 98 "Chrome Dome"
Since your car is paint code AA1 and the 3rd digit for the "Wheel" box is "A", that would mean to me the wheel was painted the same color as your car. I would then deduct that the 16 indicates some type of steel wheel.
The code 44 is the tire which is F70x14 Red Streak "Speedway" (same as mine)
I can't tell you what type of wheel cover/hub cap is code 01.
Hope this helps.
Frank
