Page 3 of 3 1 2 3
Re: Holy Crap! Check this out! [Re: BigBlockMopar] #1219691
04/26/12 11:00 AM
04/26/12 11:00 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are there any dimensional drawings available to compare your steeringbox to the stock powersteering box?
Reason for asking is that besides myseld, a number of folks are looking into installing a modernday Hemi into their Mopar A-body, while retaining powersteering.
Currently, at the driversside, the Hemi's exhaust will interfere heavily with a stock powersteering box.
It would be nice to see if your box provides more space so it won't be necessary to install a rack&pinion system for instance.
One of the problems with A-body Hemi conversions is the variation of motor placement. I was a close observer/hand lender in the development of the new TTI A-body Hemi headers that were prototyped from Troy Bray's Hemi Dart.
At the recent Spring Fling show the "off the shelf" A-body Hemi K-member Ed Debevic gave TTI did not put the motor in the correct placement for thier headers. TTI had to make adjustments to that display K-member they currently have with entire front end for mockup.
But I could get measurements from Troy's Dart and could go down to TTI and test fit this new Borgeson box in TTI's mock up/test front end. That would tell the story.
There are so many things going on in 3 dimensions a 3-view drawing I don't think will cover the uber tight fit situations.
Re: Holy Crap! Check this out! [Re: autoxcuda] #1219692
04/26/12 11:07 AM
04/26/12 11:07 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Id be willing to test fit one with my Big Block Dart. Let me know Borgeson, I gots yous!
Mopar to the bone!!!
Re: Holy Crap! Check this out! [Re: 72Swinger] #1219693
04/26/12 03:12 PM
04/26/12 03:12 PM
moparAL Offline
moparAL  Offline
Hello Jeff from Borgeson,
1. You mention your new PS box will be compatible with Saginaw & Federal pumps, Correct? With regards to pressure and flow, is it compatible with the new Saginaw TC style pumps???
2. Your power steering boxes use the standard OEM pitman arms in each application. Say on a E-body big block with aftermarket TTI 1 7/8 headers they will fit and clear with no mods the factory Chrysler PS Box with a standard OEM (NON TA) pitman arm. No mods or clearance problems. Will your PS box and a standard pitman arm in the same car, RB block same motor, and TTI 1 7/8 headers still clear everything with no mods???
3. In my opinion a lot of Mopar car owners that would be interested in your product will have headers and respectfully if you can't answer my earlier question about header compatibility it might be wise to consider sending one of your PS boxes to TTI (probably the largest seller of Mopar aftermarket headers) and see if they can confirm what headers will clear your PS box.
4. Thank You- VERY COOL NEW PRODUCT!
Re: Holy Crap! Check this out! [Re: moparAL] #1219694
04/26/12 05:09 PM
04/26/12 05:09 PM
CT
Borgeson Offline
Borgeson  Offline
CT
1. Yes, the TC pump is also easily adjustable for pressure and flow to fine tune it
2. Right now I would say yes. I do want to dimension a production piece compared to a factory Mopar power box and that will provide the final answer. Just did some quick measuring in the QC room. Mopar power = 1.5" from center of sector to edge of casting, Mopar manual= 1.25" from center of sector to edge of casting, Delphi 600= 1.25" from center of sector to edge of casting. The nose (input / valve body) of our box is much smaller than an OEM mopar.
3. I appreciate the info and if it comes down to it we have worked with header manufacturers in the past to verify fitment, no reason to stop now.
4. Thank you & Your welcome!!!
Re: Holy Crap! Check this out! [Re: Borgeson] #1219695
04/26/12 06:01 PM
04/26/12 06:01 PM
CA
Joe Dokes Offline
Joe Dokes  Offline
CA
As others have said this might be an important product for those of us swapping a GEN III Hemi into an A-Body.
To have a good idea if this is going to allow power steering with a GEN III Hemi we need measured drawings of an OEM power box, and OEM manual box, and the Borgeson unit. By comparing all three will have about a 99% understanding of whether this will succeed.
Obviously, we won't know for sure if this is going to fit until we get a the Borgeson unit, a set of TTI headers, and see if we can cram it into an A-Body with a Hemi.
All that being said, based upon the one measurement provide by Borgeson, that the measurement from the center of the sector to the edge of the casting is the same on the Brogeson unit and on the Manual box is VERY encouraging.
I look forward to seeing more pics with dimensions.
Several people have commented on the price. It is a bit pricey, but when one considers the price of a new flaming rive manual box is $500.00, this box, IF if allows power steering with a GEN III Hemi, it will be an important addition to the Mopar aftermarket. Also for the Hemi swap crowd, the Power Steering delete pulley is between $156.00 and $300.00 depending upon the source. So if you had to buy a new box + the pulley your basically at the same price point.
Regards,
Joe Dokes
Re: Holy Crap! Check this out! [Re: Borgeson] #1219696
05/01/12 06:04 PM
05/01/12 06:04 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I'm very interested in these measurements also. I'm real close to having to on my tti gen2 hemi headers to make it fit. 70 e body 528 hemi. Need a test fittment mule?
Re: Holy Crap! Check this out! [Re: HEMIDOG 70] #1219697
06/13/12 09:01 AM
06/13/12 09:01 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Any updates on this steeringbox?
Or did I read the release-date wrong?
Re: Holy Crap! Check this out! [Re: BigBlockMopar] #1219698
10/01/12 04:47 PM
10/01/12 04:47 PM
CA
Joe Dokes Offline
Joe Dokes  Offline
CA
Here's a dimensioned drawing from Borgeson.
I don't have a manual box handy, so I don't know how it compares to a factory manual box.
Regards,
Joe Dokes
7402517-BorgesonPSBox.pdf (149 downloads)
Re: Holy Crap! Check this out! [Re: Joe Dokes] #1219699
10/01/12 05:44 PM
10/01/12 05:44 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
JEFF I wonder if this Gear box is compatable wth the stock late model Hemi Power steering pumps? This would help greatly as I understand that is 1 item folks are having to work on (spend Money)is that the Stock Late model 5.7 Hemi Power Steering pumps have a high operating PSI? That is not compatable with the stock Gear boxes.
Re: Holy Crap! Check this out! [Re: sbhpcb] #1219700
10/02/12 02:22 PM
10/02/12 02:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Those are the TC pumps he was referring to a few posts above.
Re: Holy Crap! Check this out! [Re: 1_WILD_RT] #1219701
10/02/12 03:33 PM
10/02/12 03:33 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Yeah, you can't trust welds.....
That sub hit an undersea mountain. The welders who build ours subs are probably the best in the world.
Re: Holy Crap! Check this out! [Re: dart4forte] #1219702
10/02/12 04:01 PM
10/02/12 04:01 PM
CA
Joe Dokes Offline
Joe Dokes  Offline
CA
As I recall, various pumps put out differing amounts of pressure. Most Mopar boxes put out between 900 PSI and 1300 PSI, the higher the PSI the less effort it will take to turn the wheel. Great at low speeds but at high speeds this leads to less "road feel."
Big Block Dart has an article on the various pumps and pressures used by Mopar. You can read the article here:
http://www.bigblockdart.com/techpages/pspumps.shtml
Most GM pumps put out between 800 PSI and 1000 PSI, thus if you have a mopar box with 900 PSI you're probably pretty close, though the steering might be a little lighter.
If the steering is too light, or you wish to be able to adjust the level of effort in your steering, you can install an adjustable power steering valve from Heidts Hot Rods.
You can find it here:
http://www.heidts.com/steering_kits_components.html
Hope this helps,
Regards,
Joe Dokes
Re: Holy Crap! Check this out! [Re: Joe Dokes] #1219703
10/02/12 04:22 PM
10/02/12 04:22 PM
moparAL Offline
moparAL  Offline
When I talked to Borgeson months ago as I remember they tested it in the shop with a GM TC pump and then tested it in a early Charger on the road. Thanks Joe Dokes for the info on the adjustable valve.
Re: Holy Crap! Check this out! [Re: dart4forte] #1219704
10/02/12 04:22 PM
10/02/12 04:22 PM
CA
Joe Dokes Offline
Joe Dokes  Offline
CA
I think that was his point, he was being sarcastic. The sub hit something big yet survived (there were some fatalities but as you can see the sub remained intact). As you pointed out the integrity of the welds and good designed saved a lot of sailors lives that day. Running into an underwater mountain at 25 knots is typically a bad idea.
Regards,
Joe Dokes
Re: Holy Crap! Check this out! [Re: Joe Dokes] #1219705
10/02/12 05:07 PM
10/02/12 05:07 PM
moparAL Offline
moparAL  Offline
I called Heidts Hot Rods and they said the power steering valve was for a GM pump lowering pressure to a Ford rack in pinion rack. They didn't seem keen to use it on any other application.
Re: Holy Crap! Check this out! [Re: moparAL] #1219706
10/02/12 07:33 PM
10/02/12 07:33 PM
CA
Joe Dokes Offline
Joe Dokes  Offline
CA
I'd consider that a liability issue or a fitment issue more than anything else. All their device does is dump excess pressure back into the return line. On a Mopar where you are trying to reduce the pressure only slightly, you'd simply screw the adjustment almost all the way in. My guess is that since it might not be a simple bolt on, i.e. you might have to make your own lines with differing ends, they don't want to deal with the support issues.
Regards,
Joe Dokes
Re: Holy Crap! Check this out! [Re: Joe Dokes] #1219707
12/17/12 01:30 AM
12/17/12 01:30 AM
Burnaby BC
N
NMike Offline
NMike  Offline
N
Burnaby BC
so anybody have one installed yet?
Re: Holy Crap! Check this out! [Re: DARTH V8Я] #1219708
12/17/12 01:38 AM
12/17/12 01:38 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
The one thing I dont like seeing on anything that has to do with steering are welds. I'm sure you guys tested it, but I dunno.. it shouldn't be there.
Speaking of welds in place where they shouldn't be on steering components...
Ok, now back to the box...
Re: Holy Crap! Check this out! [Re: MuuMuu101] #1219709
12/17/12 05:04 AM
12/17/12 05:04 AM
The Netherlands
The Netherlands
I received my Borg-box a couple of days ago and getting ready to install it when I get the coupler and lines sorted out.
Re: Holy Crap! Check this out! [Re: MuuMuu101] #1219710
12/17/12 10:38 AM
12/17/12 10:38 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
dealer-installed firm-feel?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Page 3 of 3 1 2 3
