Re: thin cylinder walls - cooling issues ?
[Re: Dart 340]
#121957
09/17/08 11:21 PM
09/17/08 11:21 PM
Posts: 284 Chicago suburbs
dartgame
Chicago suburbs
Interesting developments:
I swapped on a used 600 cfm #1850 holley, in place of the carter afb. Idle quality immediately improved. I went from 12 inches and shaky to 15 inches and much steadier. Ran the engine until it got fully heated up at idle. Set the timing at 15 btdc.
Measured the temps on the thermostat housing - 215F, and then measured the temp at the return outlet on the bottom of the radiator - 195F !!! The radiator isn't doing the job at idle.
When I had checked temps before, I had the engine running at 2000 rpm, I had 220 at the top of the radiator and 160 or so at the bottom, but thinking back this was measured off the tank, not the return outlet, I'll bet it was a similar temp. (meaning 195F or something). I'll check that tomorrow evening to verify.
Oil temp measured off the filter is 205F
Tailpipe exh temp is 105F both sides
Header temps measured very close to the heads on the tubes range from 450 at the front (due to fan cooling probably) to around 550 at the middle two, and 500F at the rear pipe, similar temps both sides. Ive been told these temps are normal ?
So, what this is telling me is that:
#1 my carter is junk, I need to use this holley or other newer carb
#2 Either my radiator is not up to the task - or water flow at idle is not adequate. I doubt this - since the coolant flows like crazy inside the radiator near the cap anyway at idle.
#3 I think I need another radiator to make this go away. I'm guessing a two row 1.25" or 1.5" tube Aluminum radiator with a shroud will be the ticket.
If anyone has thoughts or comments about what I've found and my conclusions, please - by all means make them.
I wont be doing much about buying anything for a week or so, so please fire away.
[Re: Dart 340]
#121959
09/18/08 10:08 AM
09/18/08 10:08 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
The 2 row was stock for 340's.
In '69 all 340s had 3 rows from the factory. And all 318s with AC got the 3 rows too.
[Re: 69Cuda340S]
#121960
09/18/08 10:33 AM
09/18/08 10:33 AM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
dont know about 69 but in 70 my book shows only 2 row were used.
[Re: tpabayflyer]
#121966
09/18/08 11:14 PM
09/18/08 11:14 PM
dartgame
Chicago suburbs
GTX the plugs look good, no fouling, a little tan starting to show up (new engine still breaking in). the clutch is new and is a thermal type, its pulling lots of air. the belt is new and Im sure its not slipping. It has one belt, fan, alt, crank. (manual steering), no AC.
Mike S nothing odd about the intake gaskets, stock felpro pieces. I can also read the temps on the outlets from the heads using the infrared thermometer - they are reading the same temp as the rest of the water passages in the pump - thermostat etc. Leading me to believe its okay. No blow back issues, or anything, the block was hot tanked and then inspected by me before I installed the freeze plugs, its clean clean.
TBF - thanks for the input, the block is a 68 casting which might or might not be something special in terms of wall thickness. Im pretty sure that isn't the problem. Espcially after finding these temp issues. From what you said its the radiator. What are the specs on your radiator, surface area, maker, tube size ? I'd really appreciate the specs. if you can get them.
[Re: dogdays]
#121972
09/19/08 07:25 PM
09/19/08 07:25 PM
Posts: 650 Kansas
racincuda
Kansas
I had th same problem with a .030 over 318 using my stock radiator Switched to a new replacement 440 radiator and the problem vanished could idle for long periods, stop n go traffic with AC on, how sweet it is. Let me put it another way RADIATOR RADIATOR RADIATOR RADIATOR RADIATOR
