Re: Quench on a 340.
[Re: woody30]
#1219376
04/20/12 11:39 PM
04/20/12 11:39 PM
RapidRobert
You'd need a thicker composite gasket like the blue Felpro's. Not sure what the thickness of the FP blue SB ones are (might be .054")
[Re: woody30]
#1219377
04/20/12 11:41 PM
04/20/12 11:41 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
[edit} my bad
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1219378
04/20/12 11:58 PM
04/20/12 11:58 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Can't run a closed chambered head with the OEM high compression/domed piston. Need after market flat tops.
Edelbrock does make a version of the performer head for a stock type 340 piston. Not sure if it can be set-up for effective quench though.
That's just bad info for anyone that reads this. The stock OEM 340 piston is a flat top with valve reliefs.
I guess mine with closed chambers and flat top pistons out of the hole .022 is gonna blow up?
As mentioned, you just need a gasket the correct compressed thickness.
Those ede 340 open chamber heads are junk for building a quench engine. Makes things MUCH tougher. All the 340 sets I've had, the chamber gets cut off them so they become closed chamber! no guessing, reflector domes, none of that nonsense. Easier to build and measure with a flat surface
[Re: ohiodemon]
#1219381
04/21/12 11:13 AM
04/21/12 11:13 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
stock 340 heads are open chamber and not designed for quench. They would need a lot of machining to create a quench pad, and then (as with a closed chamber aftermarket or magnum head) you would need the thick head gaskets as noted since stock 340 flat top pistons stick above deck.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
