Re: thin cylinder walls - cooling issues ?
[Re: OzHemi]
#121939
09/17/08 11:14 AM
09/17/08 11:14 AM
Only having a 2 core radiator might be more of an issue to consider as well..
i have a 4 core in mine and it runs cool all the time- even when its 95 degrees outside
[Re: mopowergtx]
#121945
09/17/08 12:53 PM
09/17/08 12:53 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I'm just saying here but if a bigger radiator wouldnt help then why dont we all run single core 18" slant six radiators?
not sure if the rad is the issue if he has a 60 degree temp drop across it , if it's not a hi hp motor the water temp coming out at 220 is too hot in my opinion .
but then again i don't know what the temp drop across the rad should be ?
[Re: JohnRR]
#121946
09/17/08 02:20 PM
09/17/08 02:20 PM
Posts: 20,764 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Same amount of heat is being generated by a .030 engine or a .060 engine. I don't see how an extra .015 off the cylinder wall thickness can add up to very much. I had a 350 chevy in my truck that I thought was .060 over. It ran hot. When I finally retired it for the 400 I pulled the heads off the 350 and it was only .030 over. I blame the stock style water pump I ran on it. I would look at your jetting or maybe a bigger/thicker radiator. I know a guy who has a built 408 in a 65 b-cuda and it runs very cool with the stock 273 radiator, no shroud, and a small flex fan a mile from the radiator.
[Re: 540challenger]
#121948
09/17/08 03:05 PM
09/17/08 03:05 PM
Posts: 284 Chicago suburbs
dartgame
Chicago suburbs
Thanks for the replies !
The build is pretty tame. 60 over 318, purple shaft .455 lift cam (268/272) grind. 9:1 compression, shortie headers, #302 (late closed chamber) casting heads pocket ported, 1.88/1.60 valves, single plane 273 4 bbl intake, 8 blade water pump, impeller is 4 3/8 diameter, with an anti cavitation plate on it. Probably 300-350 hp. Running a stock shroud on the stock high efficiency brass/copper 2 row recored radiator, 7 blade 17 inch fan, new thermal clutch, heater core is new. hoses are new. 180 robertshaw thermostat. Nothing adds up at this point.
When I built the motor I put the freeze plugs in it and flushed the jackets. Motor was hot tanked in a caustic water hot tank.
Keep em coming.
[Re: dartgame]
#121950
09/17/08 03:35 PM
09/17/08 03:35 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
I'll measure the exhaust temp this evening. I assume the tailpipe temp is what would be suggested ?
I am not sure how to measure the oil temp. Maybe point the infrared thermometer at the oil filter ??
Boy, I am reading with interest. Mine is the same as this. Tried everything but jetting, but the plugs look good. Drives great at 50 degrees outside but when it's 80 i'm at 210-220.
