Re: School me on overdrive transmissions for a RB
[Re: DARTH V8Я]
#1219227
05/07/12 09:50 AM
05/07/12 09:50 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
You should have no problem fitting this thing under that whale.. lotsa room
I'm sure it would raise a few eyebrows if they got some installation inquiries about putting that in an Imp. Their first question for you would be how/where you got it.
A car-sized version of that would be pretty cool, but we'd have to turn to Audi (I think) to get one.
[Re: Fury Fan]
#1219228
05/07/12 01:03 PM
05/07/12 01:03 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
A518 with either a JVX adapter or JW Ultrabell. http://www.cuda-challenger.com/cc/index.php?topic=84774.0Many folks have done it in an e-body w/o hacking the car. Slapstick shifter works too. I plan on doing the same mod. I'm just curious on converter...for non-lockup. They say, that you should get stall speed that's less than what you cruise at 65mph. With 4.10 gears, and with a .75OD (3.07) and 26" tall tires, that means running 2600RPM. Does that mean I have to get a 2500 stall 'verter? That seems kinda low if you got a hot street engine.
[Re: 2fast4yourBrain]
#1219229
06/28/12 09:49 PM
06/28/12 09:49 PM
Posts: 12,187 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Someone mentioned earlier in this post that the 71-up Es don't need to have the crossmember modded but that the 70s do. Is that true? I never knew that there was a difference in the crossmember area between the years.
So, is there a difference that affects the install of a 518?
Master, again and still
