Re: rearend noise
[Re: BigTerry]
#1218998
04/20/12 01:24 AM
04/20/12 01:24 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
No, more likely the U-joint going bad. ring-n-pinion's will start to whine, but you're not going to get any "slop" there without it just breaking first.
Check the u-joint.
Re: rearend noise
[Re: BigTerry]
#1219001
04/29/12 11:09 PM
04/29/12 11:09 PM
RapidRobert
it could clunk if there's an excessive amt of backlash between the r&p. Jack up the rear & rotate a wheel back/forth. Yes you want the ujoint to be compressing the zerk rather than trying to pull the tapped zerk fitting hole apart if that makes sense in how you would orient it on installation
Re: rearend noise
[Re: BigTerry]
#1219003
04/29/12 11:30 PM
04/29/12 11:30 PM
RapidRobert
you want either ear delivering the torque to be compressing the zerk. easier to visualize when you have it in hand
Re: rearend noise
[Re: BigTerry]
#1219007
05/01/12 02:49 AM
05/01/12 02:49 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
broken tooth on a spider/idler..
I am truckless..
