4150 750 double pumper ,no adjustments? #121886
09/16/08 07:34 PM
09/16/08 07:34 PM
fort knox ky
440 trucknduster Offline OP
fort knox ky
hi all, got a 60 over 440 with a holley double pumper with four corner idle.
i have no adjustment on the idle screws? can screw them all the way in and nothing happins? jets are 84 up front, 73 in the rear,the car is running rich,real rich?
any ideas on what is wrong? please help
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121887
09/16/08 07:36 PM
09/16/08 07:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Power valves bad, vacuum leak, plugged air bleeds, plugged passages.
Re: 4150 750 double pumper ,no adjustments? [Re: NITROUSN] #121888
09/16/08 07:41 PM
09/16/08 07:41 PM
fort knox ky
fort knox ky
thnaks, i have put a 2 and half power valve in it and new base plate gaskets ,havent opened the carb its self,
is there a way to clear out the cloged air bleeds?or cloged passages? with out taking it aparts? its practically brand new??
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121889
09/16/08 07:44 PM
09/16/08 07:44 PM
Kirkland, Washington
Pacnorthcuda Offline
Are you able to back off the idle set screw until motor dies? If not, and if the butterflys stop closing at some point when the screw is backed off then the idle-stop set screw (real small in the throttle body) may be adjusted to far open keeping the butterflys in the main fuel feed circuit. ????
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121890
09/16/08 07:56 PM
09/16/08 07:56 PM
AndyF Offline
AndyF  Offline
If the idle mixture screws don't do anything then you aren't running on the idle circuit. Get it back on the idle circuit and your mixture screws will start working again.
Re: 4150 750 double pumper ,no adjustments? [Re: AndyF] #121891
09/16/08 08:01 PM
09/16/08 08:01 PM
fort knox ky
fort knox ky
ok,how would i get it back on to it
Re: 4150 750 double pumper ,no adjustments? [Re: AndyF] #121892
09/16/08 08:02 PM
09/16/08 08:02 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Happens a lot on Holleys. Close down the throttle plate, If it becomes hard to start then play with the idle screws...Also what NITROUSN said (check those first).
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121893
09/16/08 08:27 PM
09/16/08 08:27 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
What cam and how much initial timing? It might be tough to close the throttle plates without the engine stalling if you have a lot of cam and not enough initial timing.
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121894
09/16/08 09:19 PM
09/16/08 09:19 PM
Virginia
JimG Offline
JimG  Offline
Virginia
AndyF and CudaJohn are correct.
If you don't have a vacuum leak or or a problem with the carb, I'm guessing you've cranked open the curb idle screw to get the idle RPM you want.
Take tha carb off and flip it over. Look at the primary throttle plates. The 2 transition slots are, well, they're slots that are ~ .200 - .250 long. As each throttle plate opens, it uncovers more of the slot, as they close, they cover more of the slot.
I'm guessing that to get the idle RPM you want, you've got too much of the slot uncovered. When the throttle plates are closed to curb idle, you should only see enough of the transition slot that it looks like a square. If you're seeing a rectangle, that's too much.
The cure is to drill small holes in the throttle plates so you can close the curb idle to get the proper plate/slot relationship.
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121895
09/16/08 09:33 PM
09/16/08 09:33 PM
Virginia
JimG Offline
JimG  Offline
Virginia
Oh, and not that this has anything to do with your problem, but how did you end up with 84 jet in the primary and 73 in the secondry?
Re: 4150 750 double pumper ,no adjustments? [Re: JimG] #121896
09/16/08 09:39 PM
09/16/08 09:39 PM
Easy there buddy...not too fast. Look at the posts above and read carefully. ADJUST the plate stop before drilling holes. Carefully read whats posted above.
I bet Holley likes you!!!
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121897
09/17/08 07:28 AM
09/17/08 07:28 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
It is also possible that if your ignition timing is not advanced far enough , you may be having to open the throttle too much with your trying to get a high enough idle speed, and thus the carb is not in the position for the idle circuit to work. Check your timing ! You may need 10 to 15 degrees advance at idle speed. I doubt that you need to drill the throttle blades ! First, If it is real rich, you may have a needle and seat with debris holding it open or too high fuel pressure. You need to set float levels with it running see if fuel is at bottom of sight holes !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: 4150 750 double pumper ,no adjustments? [Re: doctor_mopar] #121898
09/17/08 08:02 AM
09/17/08 08:02 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
You can give the secondary throtte stop screw a crank in leiu of drilling holes.
I'd start by backing out the idle mixture screws 3 turns each. Fire up the car and back out the idle stop screw to try to get the car to the idle RPM you want then get back to us.
Check base timing while you are at it. Make sure the vacuum advance is disconnected and plugged.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 4150 750 double pumper ,no adjustments? [Re: 440 trucknduster] #121899
09/17/08 01:25 PM
09/17/08 01:25 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Your primary and secondary jets are swapped. I bet when you had it apart you switched the metering blocks. The one with the power valve and the 73 jets goes in the front. This could be your whole problem.
** IMPORTANT - Before you try anything else, Pull the fuel bowls off and make sure the Metering blocks are not switched.
Wrong Powervalve unless you have a really huge camshaft or a really bad vacuum leak.
I couldn't agree more.
1. We need to know more about the engine combo.
2. Most of the time more initial timing cures these "carb" problems. You will have to shorten the advance curve so that you can have enough initial without having too much total.
3. The info in the earlier posts about the mixture screws,transfer slots, and idle speed screws is good. You probably will not need to drill any holes. Set both of the idle speed screws so that the correct amount of transfer slot is exposed (as mentioned square is good). Put everything back together and start it up. For now resist the urge to mess with the idle speed screws. Adjust the timing to get the idle speed up where it belongs. Check the timing and see if it is reasonable (16-20degrees should be enough at idle). Now try to adjust the mixture screws. I bet they work now. Only use the idle speed screws to make very minor adjustments, remember you are trying to keep the transfer slots approximately square. You will probably need to shorten the advance curve to limit the total advance to around 36 degees. How you do this depends on your distributor.
