painting car.. remove motor/4speed or just motor? #1218757
04/19/12 06:14 PM
04/19/12 06:14 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
The 71 charger is going to the body shop so gotvto strip the car down
the 440 is coming out to have compartment soda blasted
what would be easyier to inatal? with tranny/bellhousing left in? Or yank both out as unit install as a unit? or yank both as a unit install the 440 with bellhousing/clutch then later the 4 speed?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218758
04/19/12 06:31 PM
04/19/12 06:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
yank it all!
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218759
04/19/12 06:32 PM
04/19/12 06:32 PM
Jacksonville Florida
elitecustombody Offline
Do it right and pull it all before blasting and painting
Re: painting car.. remove motor/4speed or just motor? [Re: elitecustombody] #1218760
04/19/12 07:49 PM
04/19/12 07:49 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
What about install? Motor tranny togeather or motor then tranny or tranny them motor? 440 will be going in from top
1971 charger
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218761
04/19/12 08:56 PM
04/19/12 08:56 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
It all depends on what you are comfortable with and if you have help, to guide the whole thing in.
I do it by myself and always put the tranny in first. However I have only done automatics. Might be easier to install clutch and bell before and then just hoist up the 4 speed. My belief is less chance to scratch your new paint, with a shorter assembly..
I have mechanical Aptitude.
I can screw up anything.
Re: painting car.. remove motor/4speed or just motor? [Re: bboogieart] #1218762
04/19/12 09:11 PM
04/19/12 09:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
With a 4-speed you have 2 options ... install as an assembly (my preferred method) OR install the engine and bell first then curse and swear as you try to install the tranny later.
I think a lot depends on your shop setup. Installing the tranny is certainly a lot easier if you have a hoist.
Re: painting car.. remove motor/4speed or just motor? [Re: Stanton] #1218763
04/19/12 09:23 PM
04/19/12 09:23 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
We just pulled the engine and trans from mine all as one unit. I used a screw type load leveler and it came out real easy.
Re: painting car.. remove motor/4speed or just motor? [Re: Stanton] #1218764
04/19/12 09:39 PM
04/19/12 09:39 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
^^^ Agreed. Automatics are so much easier.
Re: painting car.. remove motor/4speed or just motor? [Re: dustergirl340] #1218765
04/19/12 09:51 PM
04/19/12 09:51 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Getting it out is no problem getting it back in with out scratching is my concern
i put the 340/auto in my pro street car that wasnt bad that being said 440/stick is a differn beast
1971 charger
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218766
04/19/12 11:17 PM
04/19/12 11:17 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
whats wrong with putting it all in from the bottom?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: painting car.. remove motor/4speed or just motor? [Re: HealthServices] #1218767
04/19/12 11:21 PM
04/19/12 11:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
For some reason I never concider that, but it's probably the best bet in this case.
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218768
04/19/12 11:21 PM
04/19/12 11:21 PM
bobs66440 Offline
bobs66440  Offline
As long as you're careful and cover everything, it shouldn't be a concern. The load leveler really is the key. I wouldn't attempt it without it.
Re: painting car.. remove motor/4speed or just motor? [Re: HealthServices] #1218769
04/19/12 11:22 PM
04/19/12 11:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So easy a caveman could do it, without scratching anything.....
Re: painting car.. remove motor/4speed or just motor? [Re: 1_WILD_RT] #1218770
04/19/12 11:32 PM
04/19/12 11:32 PM
You're not kidding,it's a piece of cake.
Re: painting car.. remove motor/4speed or just motor? [Re: 1_WILD_RT] #1218771
04/19/12 11:32 PM
04/19/12 11:32 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Im not wanting to dissassemble the whole front susp. Dont have a means of moving the susp,motor,tranny under the car so in from the top it will be
1971 charger
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218772
04/20/12 01:44 AM
04/20/12 01:44 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Why send it to the soda blaster with the front suspension still hanging on it? I unbolted my k-frame, picked the car up with the cherry picker and put it up on jack stands real high. Then rolled the engine/trans/suspension out the front(was easy with the tires still on it). Took a couple of 2x4's, drilled some holes and bolted them onto the car where the k-frame bolted up originally and bolted some large casters to the 2x4's to make moving the car around easy. Makes working on everything so much easier when it's out.
Re: painting car.. remove motor/4speed or just motor? [Re: DaytonaTurbo] #1218773
04/20/12 06:16 AM
04/20/12 06:16 AM
missouri poplar bluff
lady426 Offline
lady426  Offline
Ralph here on angies comp.
Im taking to blaster cause car color is getting changed sence paying for the paint job by the hour
will be money ahead to pay the 100.00 hour for the soda blasting to have them do under the hood inside trunk and door jambs insted of paying the paint shop by the hour to sand all them areas
i think i will drop the 440in from top then install the 4 speed from under the car
1974 rallye challenger plum crazy with a 426 dual plug hemi
Re: painting car.. remove motor/4speed or just motor? [Re: toplescuda] #1218774
04/22/12 02:02 PM
04/22/12 02:02 PM
tucson az
frank Offline
frank  Offline
tucson az
I just did this in my GTX. The engine would be easier to install without the trans or bellhousing. I installed the clutch and pressure plate on the engine prior to install and it was a tight fit. If I had to do it again I would install the engine only then the rest from under the car. Best way(except from underneith) to avoid damaging the paint. Keep in mind this was done in my garage with no help. My trans was a PITA to get in from under the car though.
Re: painting car.. remove motor/4speed or just motor? [Re: frank] #1218775
04/22/12 09:47 PM
04/22/12 09:47 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I put my bigblock (RB) and 727 in as a unit, by myself, in my freshly painted Dart. No scratches or engine leveller either. Make sure the rear of the car is as high as you can safely get it, and the front as low as you can get it.
Just helps with angles.
codfish
