Just curious #1218472
04/18/12 10:19 PM
04/18/12 10:19 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
What are you guys paying for, or charging for cage and chassis work ? Spaecifically cage updates and rear half type work . Any help would be appreciated. Thanks, Beep
Re: Just curious [Re: Bigbeep] #1218473
04/18/12 10:33 PM
04/18/12 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your gonna have to be ALOT more specific on what you
are lookin for and weather its moly or mild tubing
Re: Just curious [Re: Bigbeep] #1218474
04/18/12 10:53 PM
04/18/12 10:53 PM
Out West
408strokerdart Offline
Out West
Well John.....here the going rate is $65/hr + materials.
Re: Just curious [Re: MR_P_BODY] #1218475
04/19/12 02:04 AM
04/19/12 02:04 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I am really just looking for a ballpark labor rate to charge. Have been having a few ask for my services but have never paid for them myself, so I never really followed the costs. Actually the MS/CM question I thought about right after I hit send on the OP but figured I would wait and see what came up. Both are possible here and I perfer tig if possible but I know some people will not be able to afford the CM aspect on some projects and tig isn't feasable on others. Most requests have been for cage updates so they can move up in class and repairs to mounts or the addition mounts. ie. wheelie bars and mid plates, etc.
I know Brian is quoting tig work down there in the great state. Is the bullet back together yet Brian?
Thanks guys, Beep
Re: Just curious [Re: 408strokerdart] #1218476
04/19/12 03:37 AM
04/19/12 03:37 AM
Texas
racer_amx Offline
racer_amx  Offline
Texas
Seems to be the going rate in this region but probably a little more up north
Re: Just curious [Re: Bigbeep] #1218477
04/19/12 02:16 PM
04/19/12 02:16 PM
Thanks guys, Beep
The dollar amount per hour or by the job is up to you That being said do you do this as a job full time or is it at night at home in your shop? It makes a difference on the overhead I work cheaper at home(get paid less) than on the "job"
Re: Just curious [Re: Cab_Burge] #1218478
04/19/12 08:04 PM
04/19/12 08:04 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Yeah Cab, just a little side work now and then in the shop out back. Makes the racing go a little easier in these times. Thanks, Beep
