Solvents??? What do you use to clean parts?? #1218338
04/18/12 06:30 PM
04/18/12 06:30 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
I have some parts that I needed cleaned and a old solvent tank with no solvent. Here in California you can no longer buy good solvent. What should I use that wont kill me and still works??
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Solvents??? What do you use to clean parts?? [Re: Troy] #1218339
04/18/12 07:00 PM
04/18/12 07:00 PM
IN
ahy Offline
ahy  Offline
IN
Common paint thinner works well. Is that available? Kerosene is OK... just a little slower cleaning and drying. Diesel works but is smelly and slow. Not recommended.
Re: Solvents??? What do you use to clean parts?? [Re: Troy] #1218340
04/18/12 07:06 PM
04/18/12 07:06 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Mineral spirits work too.
Re: Solvents??? What do you use to clean parts?? [Re: Dean_Kuzluzski] #1218341
04/18/12 07:09 PM
04/18/12 07:09 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
....That is what I was just looking at.
Re: Solvents??? What do you use to clean parts?? [Re: Troy] #1218342
04/18/12 07:22 PM
04/18/12 07:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can you still buy mineral spirits in California?
Re: Solvents??? What do you use to clean parts?? [Re: Troy] #1218343
04/18/12 07:51 PM
04/18/12 07:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
yep it's what I use.
I have mechanical Aptitude.
I can screw up anything.
Re: Solvents??? What do you use to clean parts?? [Re: bboogieart] #1218344
04/18/12 08:00 PM
04/18/12 08:00 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
How big are the parts? how many? while it's probably not the most environmentally sound idea, I use gasoline
but only for small parts, and NOT in a parts washer!
paint thinner, mineral spirits, etc. are all like $10-15 a gallon. Gas is "cheap" at $3.xx a gallon around here....this week.
for small parts, I pour some out into an oil catch pan, and use a paint brush. while I'm sitting outside in the gravel driveway. away from anything electrical.
then I let the parts sit and dry outside.
if it's something that needs painted, follow up the gas bath with a shot of brake cleaner and you're good to go. I've not had any problems with it
The little bit that I let evaporate up into the air or pour onto the driveway where it quickly evaporates each year, is nothing compared to the amount of gas that gets spilled at the gas station from people topping off their tanks or overfilling jerry cans on the ground, so I don't feel THAT bad for "wasting" the gas that way
**Photobucket sucks**
Re: Solvents??? What do you use to clean parts?? [Re: Troy] #1218345
04/18/12 08:07 PM
04/18/12 08:07 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
In CA check on the availability of 142 Solvent LA (low aromatic). I still stocked and sold lots when I left there 4 years ago. It should still be available. It is simply a higher flash mineral spirits with lower emissions.
Old, tired, and sometimes broke down. Me, not my car...
Re: Solvents??? What do you use to clean parts?? [Re: 70Cuda383] #1218346
04/18/12 08:48 PM
04/18/12 08:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
OMG!!! your uphill from me!! Gas in your driveway???
Yup gas is a cheap solvent and I have used it in a presurrized sprayer, works really good for heavy grime and grease.
I have done it on a concrete driveway many times and it evaporates before it get's to the grass.
For inside solvent, paint thinner, mineral spirits, stodard solvent...it's all the same and the BEST to use.
Re: Solvents??? What do you use to clean parts?? [Re: Challenger 1] #1218347
04/18/12 11:02 PM
04/18/12 11:02 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Gas in a pressurized sprayer sounds like a recipe for disaster, won't take much for atomized fuel to go BOOM.
I used to clean with gas and other solvants all the time but heard one too
many of someone hurting themselves real bad. Once my kids started helping me in the garage I started using Water based cleaners, Purple Power, Simple Green, and even Dawn dish detergent are my favorites. Get a good assortment of brushes And you will find they work as well or better with alot less cost, zero chance of explosion and environmentally friendly.
I do keep a can of lacquer thinner handy to wipe Down parts before painting.
I got rid of my parts washer and just use
a cement mixing bucket from Home Depot to soak them in.
I don't mean to preach but the thought of my son getting hurt made me re think what I do and some of the dangerous things that I did not even realize I was doing.
Give it a try you may agree.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Solvents??? What do you use to clean parts?? [Re: finadk] #1218348
04/18/12 11:23 PM
04/18/12 11:23 PM
IN
ahy Offline
ahy  Offline
IN
I was living overseas and had an OHC cylinder head re-worked at a small shop once. New (to me) car and I didn't get the timing belt changed fast enough. Anyhow, the character that replaced the two bent valves took the head into his wash bay when he was done, set it on the concrete floor and sprayed it down thoroughly with gasoline. Then he hit it hard with the pressure washer, rolling it over to get both sides. A good blast of compressed air to get the water off and it was clean and done. He just said oil it well before starting the engine... which I did. I had no problems with that head. Go figure.
Re: Solvents??? What do you use to clean parts?? [Re: finadk] #1218349
04/19/12 07:58 AM
04/19/12 07:58 AM
Cincinnati, Ohio
Cincinnati, Ohio
Pretty cool huh...? Could be a blow torch and use it to remove paint?
Seriousily, I and many others have used gas at the races to clean parts for many years. Is it the safest, NO does it work? YES, works really good.
You use common sense, We would go through 10-15 gallons on a weekend cleaning oil pans and stuff like that.
The tank.
Parts cleaner on the left sitting on the drum, we would almost fill that drum by the end of the weekend with old motor oil and gasoline from cleaning oil pans and more.
Mineral spirits is the best and SAFEST solvent to use to clean parts.
Parts cleaner on the right.
Re: Solvents??? What do you use to clean parts?? [Re: Challenger 1] #1218350
04/19/12 08:42 AM
04/19/12 08:42 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yea, but that's ok, I'm "on the other side" of the hill, my water drains north.
