How can I clean my exhaust system? #1218325
04/18/12 05:20 PM
04/18/12 05:20 PM
Colorado
CuriousYella70 Offline OP
Colorado
After a few oil leaks, road grime, etc. my TTI exhaust system (from the collectors to the tips) need a good polishing/cleaning. Is there a way to get them back to looking new w/o purchasing a new set or having them taken to a professional?
Thank all
Re: How can I clean my exhaust system? [Re: CuriousYella70] #1218326
04/18/12 05:30 PM
04/18/12 05:30 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
0000 steel wool
Re: How can I clean my exhaust system? [Re: CuriousYella70] #1218327
04/18/12 06:18 PM
04/18/12 06:18 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Re: How can I clean my exhaust system? [Re: Sinitro] #1218328
04/18/12 10:15 PM
04/18/12 10:15 PM
K
Kiddart Offline
Kiddart  Offline
K
I used a scotch bright then silica ceramic coated them. should hold up I only put about 200 miles a year on teh car.
Thank you
Kiddart
Re: How can I clean my exhaust system? [Re: Kiddart] #1218329
04/18/12 10:28 PM
04/18/12 10:28 PM
IN
ahy Offline
ahy  Offline
IN
I use Scotchbrite and mild solvent (paint thinner). Then simple green and pressure wash along with the rest of the underside of the car. Touch up of any scratches or dings with some Rustoleum aluminum paint and a small brush works surprisingly well on the steel pipes.
