Re: Cam/compression suggestions- building a 440 for towing
[Re: Danan]
#1218178
04/19/12 01:53 AM
04/19/12 01:53 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
I'm very wary of building a low compression smogger motor; I hate how they run. I'm currently running a 360 with 9:1 compression, a 340 cam, performer rpm intake and holley vac secondary.
If you want bottom-end power, high compression can give it. If you went the quench route, really upped the compression, and back the timing off you would have stump puller that shouldn't ping, right?
The new 5.7's are 10.7:1 and yet they run on 87 to 89 octane. Electronic engine management is a big factor but even so, all they do is back the timing off while still keeping high compression.
I'd like to see two engines with all identical specs except for compression ratio and timing:
1. 440 12.5 to 1 with quench, 28 degrees timing
2. 440 8.5 to 1 open chamber, 38 degrees timing
Which would make the most power?
I'd say #1
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1218179
04/19/12 10:25 AM
04/19/12 10:25 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I did a very similar exercise with my truck, but not to the extremes you asked for and I built quench into both combos.
First was an 11:1, iron head 440 with the small summit hydraulic cam. Pulling power was phenomonal and mileage was great. I was able to pass cars going up I70 to the Eisenhower tunnel, with a trailer and a '48 chevy loaded on it. On a trip to Phoenix I averaged 18 mpg. However, after the drop in elevation down in to Phoenix, detonation was bad enough to hurt a couple of pistons.
I yanked that motor and dropped in another iron headed 440, this one around 9.8:1 but with the same small summit hydraulic cam. You can definetly feel the drop in power driving around at my altitude. Mileage has also dropped some too and the best average I've managed was around 15 mpg, but I haven't taken any extended road trips with it like I did with the previous version.
The example your talking about would likely be even more extreme because the spread is much greater. IMO, you need to be very cognizant of the dynamic compression ratio you are putting into the mill and tailer it for where and how you drive.
Another interesting antecedent to this all; I took the lower compression motor to a dyno fun day with some local car club members. While I took some razzing for bringing my truck out with the muscle car guys, it all stopped when I tromped them in torque under 3500 rpm and matched the highest output 440 6bbl in horsepower, albeit mine was all done 4500 rpm, but the numbers were there. Unfortuantly, I never did a dyno pull with the higher compression engine.
[Re: TC@HP2]
#1218180
04/20/12 04:01 AM
04/20/12 04:01 AM
Posts: 815 PNW
Danan
PNW
All very interesting; this is the discussion I was looking for. I read Dunnuck's thread with interest (the first one, before he deleted all of his posts). His second thread is very good as well.
I'd really like to hear about the e-head motorhome engine mentioned above; I think this is a good direction to go in.
How about flat top pistons and either edelbrock or stealth heads to build an actual 10:1 to 10:5 static compression? I'm thinking that this could be done with cheapo TRW 2235 pistons (heavy but strong). In any case, I'm not a fan of cast or hyper-u-cracked-em pistons.
As Dunnuck's thread suggested, I'll use a performer rpm manifold, headers, and a holley vac secondary.
With an aluminum-headed 10:1(-ish) engine, what dynamic compression would you guys recommend for a tow rig using pump-junk fuel that didn't detonate? When I get home (currently deployed) I'll call comp cam and hear what they have to say.
Thanks for everyone's input; it's helping me zero in on a good engine build plan.
Semper Fidelis, Danan
[Re: Danan]
#1218182
04/20/12 08:21 PM
04/20/12 08:21 PM
Posts: 7,664 IN
ahy
IN
I think the TRW would be a good piston for the application if you could get it to zero deck and desired compression. That way, a common .038-.040" head gasket would get you perfect quench with closed chamber AL heads.
I ran the numbers and ballpark compression with this setup would be low 10's. Considering you will be running a small cam and can build up heat with sustained pulling, I'd personally go with 10:1 maximum. If you did use the TRW's and needed to drop compression a little you could probably open up the valve pockets and get what you need... to be confirmed by your piston vendor.
A cool air intake setup can help with intake temps and detonation. It could help the overall plan.
