Re: what can i expect with this suggested cam upgrade?
[Re: DirectSubjection]
#1218136
04/18/12 09:22 AM
04/18/12 09:22 AM
Posts: 3,922 n.e. pa.
65rbdodge
n.e. pa.
Can you post the actual cam specs?
you mean you don't know the specs off the top of your head?
[Re: 65rbdodge]
#1218137
04/18/12 09:39 AM
04/18/12 09:39 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
From the book.
21-224-4, 1000 to 5200, XE256H, 256/268 adv, 212/218 @ .050", .447/.455
21-672-4, 3000 to 6500, PP292H, 292/299 adv, 247/254 @ .050", .509/.509, 10:1 comp, 3500 stall recommended, the recommended valve springs will require machining the cylinder heads.
[Re: LaRoy Engines]
#1218138
04/18/12 10:24 AM
04/18/12 10:24 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The 21_224_4 is very close to my MP 268/272 .450/.455 cam Its in my 340 under a 6 pack. It has a nice lope at idle and pulls great.. I built a 350HP 360 for a friend of mine useing that same ca. In the 360 the lope wasnt as noticeable but pulled great in that car also. for his 73 Duster
I am truckless..
[Re: CUDA8U]
#1218140
04/18/12 11:01 AM
04/18/12 11:01 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
That will be a nasty cam (I'd like it :-)) Will need to be installed at 102 (101 to 103) to work with a 2800. You will need light advance springs in the Dizzy with timing 38 deg all in by 1200. 5.5 power valve That said it will kick butt. But if you lack cam, carb and distributor tuning skills like most hear you may want to pass and go with something like the hughes whiplash. What is it your really looking for?? What gears you got! and so on
[Re: CUDA8U]
#1218143
04/18/12 02:23 PM
04/18/12 02:23 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It'd work fine, although the VooDoo 533 might work a little better. The cam has good street manners. Buddy runs on in his 68 RR Similar build 9ish:1 440, e-heads, headers, M1 intake 770 Street Avgr carb, 2800 stall and 3.54 dana. Car runs has run 12.48, usually in the 12.50-55 range.
[Re: DaytonaTurbo]
#1218148
04/21/12 04:23 PM
04/21/12 04:23 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
All of you lift/duration guys...why would u want more lift...when stock heads are done (more or less) by .450??? Assuming they are stock heads... As usual on cam posts, I'll go against the grain and say that I have no issues with that cam....It will need more than 2800 flash..3500 at least... With some flash speed it will work with 55s...although not optimal. If you are stuck with the 2800, back the 050 duration down 10 degrees or so.... BTW, dont let them scare you...the cam you listed is VERY streetable, et...with the right carb, vert, etc. I ran the .509 MP cam when I was 19 and couldnt tune a radio...It would idle all day long.. I do wonder if some of the naysayers have ever ACTUALLY ran some of the stuff you knock???? I agree that you should call a cam guy. Porter or Bullet, IMO...skip the others listed. Not saying the others grinds wont work...but Porter is the man...by a long shot. Bullet is decent as well on their Mopar grinds. That ought to get the
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
