1971 Cuda NO TURN SIGNALS #1218022
04/17/12 10:34 PM
04/17/12 10:34 PM
Anonymous OP
Anonymous OP
I was going to replace the turn signal switch because thyey were intermittantly working, now I notice when I turn the park lamps on the turn signal indicators on the cluster partially light. I dont have a wiring diagram for it. Any knowns or checks? No power to the flasher when they dont work. Any help appreciated!
Re: 1971 Cuda NO TURN SIGNALS #1218023
04/17/12 11:06 PM
04/17/12 11:06 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
You have a bad dash ground ...!!!!
Re: 1971 Cuda NO TURN SIGNALS [Re: dynamite] #1218024
04/18/12 12:06 AM
04/18/12 12:06 AM
Anonymous OP
Anonymous OP
I tried grounding the dash better with my power probe applying ground places it didnt seem to make a difference, tried an old t/s switch with no change
Re: 1971 Cuda NO TURN SIGNALS #1218025
04/18/12 02:14 AM
04/18/12 02:14 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Make sure the turn-park lights are grounded well in the front valance.
Re: 1971 Cuda NO TURN SIGNALS [Re: buildanother] #1218026
04/18/12 08:21 AM
04/18/12 08:21 AM
Anonymous OP
Anonymous OP
When I went to bed last night I had no turn signals. When I woke up I had them. When I turn the park lights on, the indicators still light up, one brighter than the other. I used a remote ground and started touching dash areas, the front parking lamps, and the rear housings, no change.
Re: 1971 Cuda NO TURN SIGNALS #1218027
04/18/12 10:36 AM
04/18/12 10:36 AM
Anonymous OP
Anonymous OP
Could a un grounded or mis grounded front park lamp cause this issue??
Re: 1971 Cuda NO TURN SIGNALS #1218028
04/18/12 11:44 AM
04/18/12 11:44 AM
chicagoland,usa
chicagoland,usa
Cause the dash indicator(s) to glow? Yes. Especially if the valance mounted lamps only have 2 wires. It means the housing HAS to ground through the mounting screws. Seen a fresh painted 71 charger do it recently, grabbed a phillips screwdriver and twisted screws in and out and back in, and it was fixed.. You could also have dash issues.
Re: 1971 Cuda NO TURN SIGNALS #1218029
04/18/12 11:47 AM
04/18/12 11:47 AM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
I have dealt with this issue on my trucks.First off I made sure beyond a doubt that I had good grounds on signal/parking lights.Next I pulled the bulbs out of the side marker lights to see if it made a difference.In my case it definately did,my side marker clearance lights work through a less than sufficient backfeed system that causes problems when the bulbs are plugged in...I assume it may be the same for '71 E-bodies but don't know.
Sounds mostly like you have a grounding issue somewhere since the problem is intermitent...perhaps this wiring diagram will be helpful.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: 1971 Cuda NO TURN SIGNALS [Re: GrnMagic77] #1218030
04/18/12 11:48 AM
04/18/12 11:48 AM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
...2
Re: 1971 Cuda NO TURN SIGNALS [Re: buildanother] #1218031
04/18/12 11:50 AM
04/18/12 11:50 AM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
I had a similiar situation and it was a faulty flasher relay causing the problems. Just something to check.....
Re: 1971 Cuda NO TURN SIGNALS [Re: Moonraker] #1218032
04/18/12 12:00 PM
04/18/12 12:00 PM
Anonymous OP
Anonymous OP
Thanks for the help guys! I cant wait to get out of work to look at it again. I just bought the car and it had a rotisserie resto so I figured it was a ground through paint issue. Just cant find it, Like I mentioned I had a park lamp out but it worked while it was hanging and plugged in. I added the ground but just could have a poor test result throw me in circles. I'm used to new wiring diagrams and new technology!
Re: 1971 Cuda NO TURN SIGNALS #1218033
04/18/12 08:31 PM
04/18/12 08:31 PM
Anonymous OP
Anonymous OP
You guys are great! Bad front parking lamp housings, pigtails, and of course ground!
