Push button start? #1217932
04/17/12 08:03 PM
04/17/12 08:03 PM
Anywhere the British Secret Se...
Moonraker Offline OP
I have an old push button relay I took off of my inner fender well years ago and found it digging through all my old stuff. I remember removing it as it never worked anyway due to the relay itself or crappy wiring I replaced, but is this a push button start? What is the purpose of having it under the hood? To be able to start the car while you are working on it? Sorry if it sounds like a dumb question. Is it worth putting back on?
Re: Push button start? [Re: Moonraker] #1217933
04/17/12 08:10 PM
04/17/12 08:10 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't think any of these cars had a factory underhood starter button. so as to what the one you have is for, or what it does....you got me!
who knows what the previous owners of your car did.
could be a starter button to bump the starter while running the valves on a solid cam? if so, it'll just bump the starter over, it won't actually start the car and let it run. (unless you have the key in the "run" position, in which case, bumping the starter under the hood WILL make it run! )
**Photobucket sucks**
Re: Push button start? [Re: Moonraker] #1217934
04/17/12 08:39 PM
04/17/12 08:39 PM
Was that a 74 A body that you removed it from. I've seen em but not quite sure what it was maybe a seat belt interlock bypass
Re: Push button start? [Re: RapidRobert] #1217935
04/18/12 11:44 AM
04/18/12 11:44 AM
Yes it is a 74 A-body(Duster). I will have to take a pick of it and post it. Even the new engine bay harness has the connector on there for it.
Re: Push button start? [Re: Moonraker] #1217936
04/18/12 12:25 PM
04/18/12 12:25 PM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
I have that button on my '74 Charger...seems like it was something to do with a seatbelt/ignition reset button...don't remember for sure though...definately was not a starter button.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: Push button start? [Re: GrnMagic77] #1217937
04/18/12 12:59 PM
04/18/12 12:59 PM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
...in 1974, when all new cars and light trucks sold in the United States featured DOT-mandated interlocks that prevented engine starting unless driver and front-passenger belts were fastened.
http://search.yahoo.com/r/_ylt=A0oG7l1f4...gate-scandal-2/
Mine,while still on there,has been disconnected on my car...guess it just depends on how original you wish your car to be.
Re: Push button start? [Re: GrnMagic77] #1217938
04/18/12 03:03 PM
04/18/12 03:03 PM
Good info but how did the thing function? Did you have to pop the hood and push the button to bypass the seat belt interlock?
Re: Push button start? [Re: Moonraker] #1217939
04/18/12 03:16 PM
04/18/12 03:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, if something went wrong in the seatbelt interlock system and prevented the engine from stating, the red button could be pushed to override the system and allow an engine start ONE TIME....it would then reset and you'd have to push it again for the next start.
The interlock box interrupted the yellow wire that energized the starter relay.
Re: Push button start? [Re: John_Kunkel] #1217940
04/18/12 09:59 PM
04/18/12 09:59 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Those relays DO fail, too. A friend had a 74 Duster with that crappy system. He dang near pulled his last hair out trying to figure out why the car wouldn't start. I think that he ended up bypassing the relay and threw it as far as he could.
Jeff
