Re: Fender tags
[Re: Jamie340]
#1217517
04/17/12 06:44 PM
04/17/12 06:44 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Does anyone replicate fender tags.
Replicate? Yes. Accurately? Usually not.
If you'd like, I can show you an inaccurate tag made by datatags for a previous owner.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: Fender tags
[Re: 69CoronetRT]
#1217520
04/17/12 09:50 PM
04/17/12 09:50 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Re: Fender tags
[Re: MoparABE]
#1217523
04/18/12 01:17 AM
04/18/12 01:17 AM
JohnRR
U.S.S.A.
please post the comparison of the original vs the inaccurate repro.
yes please do so the fraud can be made less noticable ...
Post deleted by moparts
[Re: JohnRR]
#1217524
04/18/12 03:24 AM
04/18/12 03:24 AM
Re: Fender tags
[Re: A57_RT ]
#1217527
04/18/12 04:10 AM
04/18/12 04:10 AM
A57_RT
Parts Problem
Parts Problem
Re: Fender tags
[Re: A57_RT ]
#1217529
04/18/12 04:23 AM
04/18/12 04:23 AM
A57_RT
Parts Problem
Parts Problem
I bought the car on the web (here) so I never saw this tag until it arrived, but thats not the issue, there are so so many ways to spot a fake tag that unless imo the maker has spent alot of $$$$ on setup and is skilled on the codes/dates, ect..and other things it can still be spoted. I also know of a chemical test if the tags are blasted. The fake tag I got with the car will never go on the car, Id rather hjave a tagless car then a fake tag car
Re: Fender tags
#1217531
04/18/12 09:56 AM
04/18/12 09:56 AM
Posts: 131 central,pa
ply64post
central,pa
Very commendable for you to automatically assume fraud. You might consider withholding judgement of others that is based on your personal characteristics. If he does provide a photo however, could you then please post a picture of your car? You do have a collector Mopar vehicle........don't you? By all means, please share the restoration results which illustrate and exemplify the tremendous knowledge you constantly express on this forum.
Very well said.
And as with all fender tag questions::
