Octane For 8.72:1 Dynamic Comp?
#1217408
04/17/12 09:08 AM
04/17/12 09:08 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am looking for opinions on what octane I should be running on my 340. I found an online calculator to help me with the following numbers:
"measured" static comp: 9.7:1 dynamic comp showed: 8.72:1 dynamic cranking comp showed 178psi (I have used a gauge and I showed an actual avg of 180psi) my local altitude is apx. 800ft.
Early last year, I was using 89 octane without any ping but I was getting run-on at shut down. Then I swapped to the 91 octane and I have been running it ever since with no more problems. I am hoping to get some opinions to see if I could drop back down to the 89 or if 91 octane would be better suited for my engine. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Octane For 8.72:1 Dynamic Comp?
[Re: Jerry]
#1217410
04/17/12 09:36 AM
04/17/12 09:36 AM
YO7_A66
Indiana
I had Scott Brown spec out my cam and I told him that I needed to run on pump gas with the 9.7:1 compression. Could the cam design be why the cranking comp seems high with the 9.7:1 static?
Thanks for the reply.
[Re: YO7_A66]
#1217411
04/17/12 10:49 AM
04/17/12 10:49 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
Did you specify the grade fuel you wanted to use or did you just say pump gas ? The cam design has everything to do with it.
[Re: JohnRR]
#1217412
04/17/12 11:44 AM
04/17/12 11:44 AM
YO7_A66
Indiana
I am trying to think back 7-8 years ago when I bought the cam and I do remember saying pump gas but I am not sure if I told him the grade of the pump gas. I just checked out the cam card and I don't show any old notes that I may have given Scott at that time.
Thank you for the reply.
[Re: rbstroker]
#1217418
04/17/12 07:44 PM
04/17/12 07:44 PM
DaytonaTurbo
Manitoba, Canada
My 9.9:1 static has a lot lower cranking compression than yours and I still have a slight pinging issue at times using premium pump gas.
Cylinder head type and design, quench or no quench, ignition timing and a/f ratio all have just as much of an effect as cranking compression. You really have to balance everything if you want to run on the ragged edge.
[Re: DaytonaTurbo]
#1217419
04/17/12 08:56 PM
04/17/12 08:56 PM
Posts: 3,916 usa
lewtot184
usa
this is the way i look at it if your trying to push the envelop for pump gas.
[Re: YO7_A66]
#1217420
04/18/12 07:42 AM
04/18/12 07:42 AM
YO7_A66
Indiana
"" "measured" static comp: 9.7:1 dynamic comp showed: 8.72:1 dynamic cranking comp showed 178psi (I have used a gauge and I showed an actual avg of 180psi) my local altitude is apx. 800ft.""
I read in another thread that the valve timing (Closed, INT) has allot do do with the dynamic compression. My current cam card shows:
Valve Timing @ .050 OPEN CLOSE INT: 5.0 btdc 41.0 abdc EXH: 55.0 bbdc 3.0 atdc Lobe CL intake: 108 exhaust: 116 Lobe Sep: 112 installed at 108
Does my current 41.0 contribute to the higher than expected dynamic compression (8.72:1)? If so, can someone give me a brief description as to why? I am not interested in changing cams, I just want to understand more about the one that I have.
Thank you all for your responses. It appears that I will continue using 91 octane.
[Re: lewtot184]
#1217422
04/18/12 09:57 AM
04/18/12 09:57 AM
YO7_A66
Indiana
The 91 octane has been fine with my current setup. I was just trying to see if I could get away with less octane or not. My cruise A/F is in the 14.0-14.8 range and after some recent secondary adjustments, I have no audible detonation at any time (cruise or any WOT conditions).
EDIT: In general, does the higher cylinder pressure (180psi) along with the higher dynamic compression (8.72:1) result in richer idle A/F ratios?
I have found that this motor idles with the best vacuum number when I am running 13.2-13.4 A/F in D. I have tried a few different times to lean it out to the upper 13's to low 14's and it does not like to idle in D at that leaner A/F ratio. I was just curious if the above is related to this. Thanks again.
[Re: PJ68RT]
#1217424
04/18/12 11:20 AM
04/18/12 11:20 AM
YO7_A66
Indiana
I used two different online calculators and they did not specify if the INT/CLOSE number was to be at .050 which is on my cam card, or at the seat to seat which I do not show on my cam card. I assumed that it was at the .050. This is one that I used. http://www.wallaceracing.com/dynamic-cr.php
