Re: Compression Ratio for pump gas [Re: DaytonaTurbo] #1217374
04/22/12 10:54 PM
04/22/12 10:54 PM
San Jose, CA
Justins72 Offline OP
San Jose, CA
thank you for the suggested cam, but im really wanting a roller cam for longevity and less friction. I did look into one with a longer duration then the ones I mention. Its a 222/228 @.050 .510/.510 lift 110 LSA rpm range about 2000-6100. With aluminum heads, dished piston, .060 head gasket (to get about .035 quench), and the cam I just mentioned I get a static compression ratio of 9.764 and dynamic of 8.484. How does that sound for pump gas?
Re: Compression Ratio for pump gas [Re: Justins72] #1217375
04/22/12 11:02 PM
04/22/12 11:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That cam would do fine on pump gas with 10:1 CR, quench and aluminum heads. Now adays with there being good, hi-zinc oils on the market made for us muscle car guys I am more comfortable with a flat tappet cam than a roller cam with lifters that have bearings and roller wheels. Not to mention cam buttons and bronze oil drive gears.
Re: Compression Ratio for pump gas [Re: Justins72] #1217376
04/23/12 12:12 AM
04/23/12 12:12 AM
IN
ahy Offline
ahy  Offline
IN
Its bored .030 over stock stroke. Any suggestions on a hyd roller cam? For compression i should aim for around 9 with iron heads and around 10 with aluminum?
That's in the right ballpark for CR.
On the lifter debate... if you were putting in an engine built from a Magnum core (designed for roller lifters) I would say no doubt run the roller with the excellent well developed OE lifters and a suitable new or re-ground cam. Starting with a 340 flat tappet... not so sure its a good idea to run roller in a mild performance build. Besides cost, many require a bronze OP gear which can be short lived plus it takes some setup. With high zinc oil, the FT lives well I believe. Even with "belt and suspenders" meaning a nitrded cam and EDM drilled oil hole lifters its cheaper.
Re: Compression Ratio for pump gas [Re: ahy] #1217377
04/23/12 01:45 AM
04/23/12 01:45 AM
San Jose, CA
San Jose, CA
Main reason Im pushing for roller cam is cause of the break in on first start up. I know your suppose to keep it reved pretty high for a half hour. Since its going to be fuel injected with the FAST EZ-EFI it has to learn to run. I dont want to mess anything up and dont want to flatten the lobes.
Re: Compression Ratio for pump gas [Re: Justins72] #1217378
04/23/12 02:08 AM
04/23/12 02:08 AM
Manitoba, Canada
Manitoba, Canada
Break it in with a carb. Putting an efi system on mine and I'm doing that. Probably easier on the rings than an overly rich universal efi system trying to tune itself while the rings seat.
I'd only run a roller like that in a SB if starting with a magnum engine that I could just have the stock roller cam reground.
Re: Compression Ratio for pump gas [Re: DaytonaTurbo] #1217379
04/23/12 07:36 PM
04/23/12 07:36 PM
San Jose, CA
San Jose, CA
I suppose I could use the carb to break it in, problem being is im not even sure the carb was tuned right before I took it off. I can set my target air fuel ration on the ecu to more on the leaner side. It uses a wide band o2 to read mixture and adjusts from there.
Re: Compression Ratio for pump gas [Re: Justins72] #1217380
04/24/12 10:26 PM
04/24/12 10:26 PM
IN
ahy Offline
ahy  Offline
IN
For the EFI break-in triple or quadruple check your setup. Injector size, displacement, closed loop parameters ect. Also I'd open up the "closed loop correction limits". With a good oxygen sensor 25% isn't too much for start-up.
