B-Body master cylinder help needed..... #1216912
04/16/12 01:05 PM
04/16/12 01:05 PM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
Having a hard time finding a master cylinder for my 69 Charger RT. I have discs / drums stock and can only find a Cardone reman part # 10-1475 (Advance Auto), not a new one. Suggestions on where to order a new one?
The hard lines bolt into the m/c from the valve cover side. That has been the issue on my car. When I search pics of 440 Magnum, they all show hard lines coming up on the fender side. I did find a pic of a 440-6 pak car and it had the m/c lines from the valve cover side & that's what I need. Is it possible this car was equipped with a 440-6 m/c by mistake? The hard lines look original, do not look like they were ever changed. HMM? Thanks. TC
Re: B-Body master cylinder help needed..... [Re: tcs69rt] #1216913
04/16/12 01:11 PM
04/16/12 01:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You could try Wayne "the Ramman", member here, also on Ebay, makes new repro brake componets, as well as masters
Usually lines "inboard" is a 1970 application, other than 69 Daytona
Fenco (Autozone)PN# M1475 (rebuilt) is for a 1970 B Body disc/drum power application with lines "inboard" (engine side) if that helps you?
NAPA also uses the 10-1475 part number for it's line of Truestop master cylinders, they are listed as "NEW"...again lines are inboard (engine side)
Mike
Re: B-Body master cylinder help needed..... [Re: DAYCLONA] #1216914
04/16/12 01:36 PM
04/16/12 01:36 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Engine side lines are correct for 383-440 cars in '69.....fender side lines are for Hemi only.
NAPA was reproducing these for a while. This is what I have on my '69 Charger R/T
Pics & comparisons in this link....
NAPA master
Mike
1MYTGTX
Re: B-Body master cylinder help needed..... [Re: tcs69rt] #1216915
04/16/12 02:06 PM
04/16/12 02:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Got them on hand( no core charge) if you can't find it locally
http://www.ebay.com/itm/NORS-Master-cyli...=item35b4848991
