Quick Strut #1216705
04/15/12 11:33 PM
04/15/12 11:33 PM
SD
Z
zrxkawboy Offline OP
Z
SD
Any opinions on the Monroe Quick Struts? Thanks!
It's Swifty! Swifty, you toad sucker!
Re: Quick Strut [Re: zrxkawboy] #1216706
04/15/12 11:40 PM
04/15/12 11:40 PM
Minneapolis, MN
moparguy Offline
moparguy  Offline
Minneapolis, MN
i've used them numerous times. They work great. And IMO are a much better deal than going the other way.
Re: Quick Strut [Re: moparguy] #1216707
04/16/12 02:09 AM
04/16/12 02:09 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I have a 95 minivan that I had to take apart and re-assemble 3 times before i finally got the spring to seat correctly on the upper strut bearing.
I wish I knew these were available at the time. If I ever do another one I will use the quick strut.
Its is well wort the extra $$ in the time you will save.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Quick Strut [Re: moparguy] #1216708
04/16/12 07:02 AM
04/16/12 07:02 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I installed quite a few at work.They are great.If you have any mechanical ability you can do them in your drive.Saves R&R labor and an easy job.Rocky
Chrysler Firepower
Re: Quick Strut [Re: therocks] #1216709
04/16/12 08:17 AM
04/16/12 08:17 AM
SD
Z
Z
SD
Sounds like these are the way to go, then. Thanks guys!
Re: Quick Strut [Re: zrxkawboy] #1216710
04/16/12 08:25 AM
04/16/12 08:25 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
i've done 2 sets so far (both toyotas) and both were perfect. they were less than $20 a pair more than bare struts
Re: Quick Strut [Re: gtx6970] #1216711
04/16/12 11:30 AM
04/16/12 11:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The ones I did were anywhere from 40 to 80 bucks more than a bare strut.But you get new springs,bearing plates etc.That and you dont have to pay someone at the least to compress them and put the new struts together.Rocky
Chrysler Firepower
Re: Quick Strut [Re: therocks] #1216712
04/16/12 02:00 PM
04/16/12 02:00 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I've changed alot of those have never had one that wasn't put together right.
