Re: Indy 440-25 intake explosion with popoff valves long [Re: max_maniac] #1216590
04/16/12 10:24 PM
04/16/12 10:24 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
The throttle blades were cracked as I always have them the throttle was bumped a few times getting the carbs off but not opened up all the way or "pumped" also the car sat with no carbs and a fender cover over the intake for over an hour while I got my sons car going that should have been plenty of time for the fuel to evaperate I thought but we all know what happens to thought I am a little concerned about the intake valves hard to beleive there was an explosion big enough to blow the intake off and it didn't pop the intake valves open and hit pistons has anyone had bent valves after the big boom
Re: Indy 440-25 intake explosion with popoff valves long [Re: biff426] #1216591
04/16/12 10:52 PM
04/16/12 10:52 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
fuel needs heat to atomize or it will fall out of suspension puddling more fuel. when the fuel falls out then the engine goes lean and you get a backfire. this is the reason OEM put a heat crossover in intake manifolds
Re: Indy 440-25 intake explosion with popoff valves long [Re: sixpackgut] #2865821
12/28/20 05:41 PM
12/28/20 05:41 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I know this is an old thread but does anyone have any part numbers or suppliers for these blow off valves for a 426 Max wedge cross ram.. I looked and could find nothing.. Thanks in advance.
Re: Indy 440-25 intake explosion with popoff valves long [Re: QuickBpBp] #2865840
12/28/20 06:54 PM
12/28/20 06:54 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Here ya go. This should help
Re: Indy 440-25 intake explosion with popoff valves long [Re: Sammy] #2865856
12/28/20 07:40 PM
12/28/20 07:40 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Something we do on those, in addition to the sneeze valves is plastic screws. They act like a sacrificial part. If and when it pops you just roll back to the pits, replace the screws and go again. No damage to the intakes and off you go.....Todd
Re: Indy 440-25 intake explosion with popoff valves long [Re: sasquatch] #2865931
12/28/20 11:10 PM
12/28/20 11:10 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Sasquatch, Thats a good idea that I hadn't thought of, are you using any sealant where the top and base bolt together? Mine leaks unless its sealed with silicone or the Right Stuff, thanks for the great idea
Re: Indy 440-25 intake explosion with popoff valves long [Re: wyoming] #2865938
12/29/20 12:00 AM
12/29/20 12:00 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You can use the Right stuff or have the manifold o-ringed if you are feeling spry.
Todd
Re: Indy 440-25 intake explosion with popoff valves long [Re: sasquatch] #2865947
12/29/20 01:37 AM
12/29/20 01:37 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
I run the same Wilson sneeze valve, but what I also have done is to separate the cranking and ign circuits.
Now I give it some pump shot, give it 20-30 secs, crank it over then add fire....lights off nice everytime.
Works like a charm wink
Re: Indy 440-25 intake explosion with popoff valves long [Re: sixpackgut] #2865966
12/29/20 07:50 AM
12/29/20 07:50 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Lot of truth in this.
Lean is the cause. If any one cylinder is lean, you will have your ignition source. Any fuel that puddles adds to the boom. You can stay with carbs, and create a vent for the path for the inevitable boom, or inject it and solve the issue. You will not likely be able to evenly distribute the fuel with carbs. Having choked carbs would help. Less air for the lean condition. Open throttle plates on start up seem like a double edge sword. Creates the lean condition, but does help vent the backfire if not to excessive.
Take any engine and start taking fuel away... even your lawnmower. It will start popping through the intake. Doesn’t matter if the engine is in perfect condition, timing is correct, engine speed, it will pop when lean. Now you take that phenomenon and add an intake with huge surface area for that pop to work against....
Re: Indy 440-25 intake explosion with popoff valves long [Re: TRENDZ] #2865971
12/29/20 08:21 AM
12/29/20 08:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you have a factory style cross ram, it doesn't need a blow off. In fact if started correctly the Indy 440-25 doesn't need one either. Mine popped the lid once. Wasn't even a big bang. Just a poof. Once I learned how to start it, never ever another issue. It does have a pop off but has never banged it. Cold start; fill bowls with electric pump, shut pump off. Pump throttle 3 times. then let it set 30 seconds. 1 more pump, ignition on, throttle cracked slightly. It should fire up on one revolution. Warm start does not require the 3 pumps. Very cold (less than 45-50 degrees) through a cloth fender cover over the carbs then use the standard cold start procedure. My car has 700+ passes with this intake. This procedure works.
Doug
Re: Indy 440-25 intake explosion with popoff valves long [Re: dvw] #2866083
12/29/20 02:19 PM
12/29/20 02:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
Doug
This be true up scope
I've saw this same issue years ago with the Eddy STR type (Street Tunnel Ram) intakes whiney
Re: Indy 440-25 intake explosion with popoff valves long [Re: Cab_Burge] #2866217
12/29/20 08:11 PM
12/29/20 08:11 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Thanks for all the responses..
Re: Indy 440-25 intake explosion with popoff valves long [Re: QuickBpBp] #2866687
12/30/20 06:43 PM
12/30/20 06:43 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
I walked into a shop one time, about half an hour after a guy "popped" a Rat Roaster on a Hemi. He said "What?" a lot for another hour. Then there's the story Allyn Lee has told me, a few times, about how he wrecked an intake AND the hood on their 68 car at the Winters. He said it was a toss up if that scared him worse than the time they cut down the bump stops on the control arms only to find it makes the car really spooky when you drop the nose at a buck-forty.
Re: Indy 440-25 intake explosion with popoff valves long [Re: dvw] #2866693
12/30/20 06:51 PM
12/30/20 06:51 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Doug
Probably have around 1000 on mine since 2011. I do the exact same procedure except I get the engine spinning with the starter before I hit the ignition. Only time I ever had a problem was on a 40° day when I thought the motor had heat in it and it was dead cold.
Re: Indy 440-25 intake explosion with popoff valves long [Re: Kevins493] #2868104
01/02/21 01:34 PM
01/02/21 01:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Not everyone understands the proper starting method or the tuning methods as well as temperture conditions and can have an intake explosion unexpectedly.With that being said I can recall many -25 manifold
mishaps and some racers more than once.We installed pop-off valves on many and on more than a dozen we welded the intake floors to prevent gas puddling or buildup in the manifold.I recommend anyone running that manifold to excercize care when starting usually a couple of pumps and hold the throttle slightly open before cranking.The installatiom of pop-off valves will insure you don't blow the top of the intake off and the welding of the floor eliminates the problem.Years back I shared the information with Indy but I never seen any change in the manifold'instead they offered an epoxy insert to install in the manifold it did little to correct the problem and killed the idea of a large volume intake which helped the larger displacement engine making the 440-25 manifold not much if any better than a Mod-Man.
Just my thoughts and observations
Respectfully Bob shruggy
