Re: Indy 440-25 intake explosion with popoff valves long
[Re: biff426]
#1216571
04/15/12 10:14 PM
04/15/12 10:14 PM
Posts: 1,505 TN
SCATPACK 1
TN
Used to have this problem with the Edelbrock Rat Roaster on my Hemi. Welded up 2 different tops because of this problem. After I changed to an electronic ignotion, I never had any more isues with it. Not sure why that made any difference. Hope you get it fixed. Have you modified your intake any to prevent puddling of fuel? Might help
Old Geezer Racing
[Re: biff426]
#1216572
04/15/12 10:15 PM
04/15/12 10:15 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Thats ugly and hate to hear it as I have done that to 2 diff ones so anyway I had Bob George fix both of them and he put on his "sneezer valves" and I have not had an issue since. However I am still very gun shy when starting the engine and cringe all the time. I know when starting you HAVE to have your foot into the throttle to keep the blades open to prevent any intake blow ups. The top and bottom can be fixed to use again so don't write off the whole season. See pics of what mine look like and I have one on each side Russ
[Re: max_maniac]
#1216573
04/15/12 10:25 PM
04/15/12 10:25 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i have just discovered the greatest thing in the world. same thing would happen to my sheetmetal tunnel ram and it happens to other guys sheetmetal rams that i know about.
since your useing the same carbs as me, i will let you in on what i have done. i left the chokes on and installed a manual choke cable and it works awesome! my car runs like my daily driver now. I can start the car and imediatly drive it anywhere
i really dont know if i would lose any ET or MPH but I dont care
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1216575
04/15/12 10:30 PM
04/15/12 10:30 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Wow sorry to hear that. I saw you race last year with the 422 club as my brother Gary Nies has the blue 64 Fury and I went with him to US 13 last year. Your car looked and launched great. Sorry to hear about this. Ron
[Re: biff426]
#1216578
04/15/12 11:54 PM
04/15/12 11:54 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Good luck they are the valves I have on mine didn't stop a thing
Well, that really sucks! I thought/hoped I had that under control. Sorry to hear about your problem. I hope you get it sorted out.
[Re: FastmOp]
#1216585
04/16/12 03:19 PM
04/16/12 03:19 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
In about 450 passes it happen to us one time. We have a pop off valve and we made a gasket for the lid. So when it went it pushed out the gasket so we just had to put in another gasket.
JAKES AUTOMOTIVE
[Re: bwdst6]
#1216588
04/16/12 09:43 PM
04/16/12 09:43 PM
Posts: 9,824 MI, usa
dvw
MI, usa
Rich will let you run a single 850 if you want and you can still run with 422.
Really?
But anyway, the right way to fix this problem is to NOT have fire in your intake! You should never, ever have fire in your intake!!! NEVER!
This comment makes sense. I blew up a Magnesium Hemi Crossram that had the lid raised 1" It turned out the cars owner had lashed the valves wrong and it hung an intake open. The thought about the ignition firing when switched on is an interesting theory. No fire should yield no explosion.
Did you have the throttle blades open? The fuel came from somewhere. Were the throttles pumped during the blade repair? No blaming here just trying to determine the cause. I had one of the very early manifolds. Never had a problem starting with the throttles open. New engine will have one as well. Doug
[Re: biff426]
#1216589
04/16/12 09:46 PM
04/16/12 09:46 PM
max_maniac
Aurora, Oh.
I have 2 Turbo start 16volt batteries in it I guess I just don't know what the heck I am doing
It's not you ===== here is another true story that happened to me at a CC Events Race in Michigan and others saw it. I had mine running and I was cruising through the pits heading toward tech and just tapped the gas and the intake exploded and blew the hood off. Several Moparts members saw this happen so it not only happens on start up Now I do know many who have run this intake for years and never once had an issue so not sure what the contributing factors really are.
Russ
