340 cam upgrade - P4452761 #1216455
04/15/12 08:42 PM
04/15/12 08:42 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
I'm freshening a stock 1970 340 and thinking about upgrading the original cam to the mopar performance P4452761 268/272 450/455 cam .
The 70 cuda has the original exhaust manifolds and a 3:23 gear ratio.
Does anyone run this cam and how do you like it......does it still make good low end torque?
Re: 340 cam upgrade - P4452761 [Re: mk_] #1216456
04/15/12 09:12 PM
04/15/12 09:12 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
Been running this cam in multiple 340's for years. I've run it with manifolds and headers. Gives it a slighly noticable idle but otherwise it runs like the stock cam. In other words it's not gonna kill low end torque.
Re: 340 cam upgrade - P4452761 [Re: Mopar73340] #1216457
04/16/12 09:04 PM
04/16/12 09:04 PM
dogdays Offline
dogdays  Offline
MP used it in their (famous) 318 buildup where they got more than 300 hp from a 318 with ported 302 heads. Not a bad cam.
R.
Re: 340 cam upgrade - P4452761 [Re: Mopar73340] #1216458
04/16/12 11:06 PM
04/16/12 11:06 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
That sounds like it should work well........thanks guys
Re: 340 cam upgrade - P4452761 [Re: mk_] #1216459
04/17/12 01:06 AM
04/17/12 01:06 AM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
if you like a raunchy idle check out different videos on youtube with the hughes whiplash cam and i hear they are an excellent power maker
Re: 340 cam upgrade - P4452761 [Re: CUDA8U] #1216460
04/17/12 02:20 AM
04/17/12 02:20 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have that cam in my 340 under a 6 pack in my shorty. I absolutely love it. Great mild lope/sound. Works great with the trio.
I am truckless..
