69 charger fuel line #1216406
04/15/12 06:44 PM
04/15/12 06:44 PM
pgh pa
captaindodge Offline OP
pgh pa
It seems my fuel tank supply line nipple is 3/8 but the fuel line is 5/16. If I use 5/16 hose it will not go on the tank fitting and if I use 3/8 it is to loose on the fuel line. What is the proper size hose ?
Re: 69 charger fuel line [Re: captaindodge] #1216407
04/15/12 06:52 PM
04/15/12 06:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is no correct hose, you have a mismatch of parts.
Is it a 440 or hemi car? If itis not then it should have a 5/16 pickup , if it is then you have the wrong body line .
Re: 69 charger fuel line [Re: captaindodge] #1216408
04/15/12 06:56 PM
04/15/12 06:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds like someone put a 3/8" pickup in the gas tank when it should have been 5/16". 3/8" in the tank is not good with 5/16" line because there is no good way to hook it up that I can think of.
Re: 69 charger fuel line [Re: JohnRR] #1216409
04/15/12 07:13 PM
04/15/12 07:13 PM
pgh pa
pgh pa
This is 440 R/T car I have had since 73. I am sure the line and the tank are original.
Re: 69 charger fuel line [Re: captaindodge] #1216410
04/15/12 08:07 PM
04/15/12 08:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If its a 440 car the line size is 3/8. It most likely has a 1/4 return line also. What did the hose look like that you removed? As said you have mixed parts.
Re: 69 charger fuel line [Re: NITROUSN] #1216411
04/15/12 09:03 PM
04/15/12 09:03 PM
pgh pa
pgh pa
This is my reply from dodge charger.com That's the correct (i.e. factory-correct) configuration, strange as it may seem. I've used 5/16" rubber fuel line before and just slowly worked it onto the sending unit's 3/8" stub. It ain't easy...
If you're restoring the car, a swap to 3/8" fuel line up to the fuel pump is a pretty common and fairly inexpensive change to make. The return lines are 1/4" regardless.
Re: 69 charger fuel line [Re: captaindodge] #1216412
04/16/12 12:56 AM
04/16/12 12:56 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Do not stretch the fuel line over the 3/8 fitting. It will eventually crack and break.
Go to the hdw or parts store and buy one 5/16 male barb nipple with 1/4in Male pipe thread and one 3/8 male barb nipple with female 1/4 inch pipe and screw them together. Use the apporiate end for the size you need.
use only brass fittings.
