Will Just Emergency Brake Be OK? #1216381
04/15/12 06:18 PM
04/15/12 06:18 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Cuda rear end is up on jack stands. No brake plumbing in the car yet, just the foot emergency set up (new shoes). Can I start it up with the brake applied, put it in gear and ease off to let rear wheels spin in both forward and reverse and apply brake to stop? Oviously braking in between. Just put in a newly balanced drive shaft and want to see it spin
Grandma always said I had "hands of gold"!
Re: Will Just Emergency Brake Be OK? [Re: CHRGR69] #1216382
04/15/12 06:29 PM
04/15/12 06:29 PM
Yes the E brake will stop it, you'll be idling then stopping it w the Ebrake then shifting gears
Re: Will Just Emergency Brake Be OK? [Re: CHRGR69] #1216383
04/15/12 06:36 PM
04/15/12 06:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
didn't know E-body's had front E-brakes. learn something new every day
Re: Will Just Emergency Brake Be OK? [Re: mikemee1331] #1216384
04/15/12 06:47 PM
04/15/12 06:47 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Whaaaaaaaat?
I have mechanical Aptitude.
I can screw up anything.
Re: Will Just Emergency Brake Be OK? [Re: CHRGR69] #1216385
04/15/12 06:49 PM
04/15/12 06:49 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i dont see why not as long as your not tryin to stop it from a high rpm.i use my parking brake all the time when im tunin the carb and dist.
Re: Will Just Emergency Brake Be OK? [Re: bboogieart] #1216386
04/15/12 06:51 PM
04/15/12 06:51 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Whaaaaaaaat?
Huhhhhhhhh??????
Re: Will Just Emergency Brake Be OK? [Re: CHRGR69] #1216387
04/15/12 06:54 PM
04/15/12 06:54 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: Will Just Emergency Brake Be OK? [Re: bboogieart] #1216388
04/15/12 07:01 PM
04/15/12 07:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Whaaaaaaaat?
ha, ha, ha! i totally missed what he was asking! sorry, retard day......
Re: Will Just Emergency Brake Be OK? [Re: mikemee1331] #1216389
04/15/12 07:05 PM
04/15/12 07:05 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Whaaaaaaaat?
i had to go back and read 3 times after yor post.
Re: Will Just Emergency Brake Be OK? [Re: bonefish] #1216390
04/15/12 07:08 PM
04/15/12 07:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
me too.
Re: Will Just Emergency Brake Be OK? [Re: bonefish] #1216391
04/15/12 07:14 PM
04/15/12 07:14 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Actually had me second guessing myself
Re: Will Just Emergency Brake Be OK? [Re: mikemee1331] #1216392
04/15/12 08:09 PM
04/15/12 08:09 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That means then you already knew B body's had front b brakes then.
Re: Will Just Emergency Brake Be OK? [Re: CHRGR69] #1216393
04/16/12 07:36 PM
04/16/12 07:36 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
If it is not too late, let me suggest putting a couple lug nuts on to hold the drum in place, if you aren't actually putting on a wheel/tire.
DAMHIK
And keep in mind how fast the wheels will be turning...
It takes gasoline to interest me.
Re: Will Just Emergency Brake Be OK? [Re: mikemee1331] #1216394
04/16/12 07:53 PM
04/16/12 07:53 PM
dogdays Offline
dogdays  Offline
Only the front wheel drive E-bodies had front emergency brakes!
R.
Re: Will Just Emergency Brake Be OK? [Re: VL21] #1216395
04/16/12 08:36 PM
04/16/12 08:36 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
DAMHIK
Wheels on there. Just at idle speed.
Re: Will Just Emergency Brake Be OK? [Re: dogdays] #1216396
04/16/12 08:47 PM
04/16/12 08:47 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
R.
anybody else?? i deserve it
