Re: Pros and Cons of Undercoating
[Re: DPelletier]
#1216137
04/16/12 09:08 PM
04/16/12 09:08 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
For something I'd drive daily in rain, parts of winter when there's no snow, then I'd undercoat it. My 68 was done and the floors are still perfect other than the trunk floor I replace, so it's getting redone. On my challenger, I used sem rock-it truck bed liner. Looks similar to undercoat, but it's very durable and washes clean very easily. It's also available in tintable. However on something really nice, I'd do paint or epoxy for a factory look.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: HPMike]
#1216139
04/16/12 09:43 PM
04/16/12 09:43 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The bottom of the tank on my Hemi Challenger is coated, and I am 100% sure that it is original. Also had a survivor '70 GTX in here that had the bottom of the tank coated as well.
MB
I don't doubt that a bit Mike, I was speaking of Los Angeles cars, and even those vary in the amount of coverage they get, most I've seen from that plant have had very little on the fuel tank, mostly just a dusting of splatter over spray or a small build up near the forward/axle side.
[Re: ScottSmith_Harms]
#1216140
04/16/12 09:44 PM
04/16/12 09:44 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
MB
I don't doubt that a bit Mike, I was speaking of Los Angeles cars, and even those vary in the amount of coverage they get, most I've seen from that plant have had very little on the fuel tank, mostly just a dusting on splatter or a small build up near the forward/axle side.
thats usually what I have seen, just some overspray on the gas tank
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: DPelletier]
#1216143
04/16/12 11:53 PM
04/16/12 11:53 PM
Posts: 2,592 None
71rm23
None
Some cars got full undercoating from the factory, some were done at the dealership and some weren't undercoated at all (except the wheelwells as mentioned previously).
Obviously the undercoating has helped preserve the car and so the answer as to what to do depends on you: what are your plans for the car?
In my case, my car will never see snow, never see a dirt road and rain will be avoided; it won't be going out of it's heated shop in the winter and will likely only get driven a few times a month seasonally....therefore there is no need whatsoever for full undercoating and I like being able to see everything under the car clearly. I also think that should I ever sell the car, buyers will also want to clearly see the condition of the underside of the unibody.
Now, if you are planning on using your car as a year round daily driver, I'd put the undercoating back on.
I'm leaning towards not putting it back on. I wont be driving it in the elements of weather. Thanks for helping me make the final decision, Dave
#1216148
06/18/12 01:47 PM
06/18/12 01:47 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
While it is true that most if not all LA plant cars did not recieve sound deadener in the forward wheel wells, every original car I've seen DID have blackout paint in the front wheel well areas to cover the body color, some had more than others but there was an effort to hide the body color made none the less.
I would do this. I would maybe use thinned out bedliner coating so that it wouldn't chip off.
